Old 05-02-2013, 09:27 AM   #11
TURBS's Avatar
Originally Posted by kscr4 View Post
Thanks Turbo...
I checked that one and saw the horizontal fuse but in my haste I overlooked the smaller vertical fuse...it will be later today before I can get back in there...
That pict looks exactly like my set up...
Post back what you find.
Old 05-02-2013, 09:28 AM   #12
TURBS's Avatar
Originally Posted by ynott96 View Post
A surge protector would have eliminated the need to "unplug"....just a thought
George
Was thinking the same lol.
But most likely would not help on a direct lightning strike.
Old 05-02-2013, 08:41 PM   #13
I checked both fuses and they look like they are good..the wire element was intact on both...I'll change them both on Friday while I have it apart. Will the control panel go bad...I have the Dometic factory book but it doesn't really help in this situation.
06 Rockwood 8285SS
97 Z71 Chev
Firestone Air Rides(thanksYouroo)
2010-33 nites
2011-41 nites and growing
2012-29 with more to come
kscr4 is offline   Reply With Quote
Old 05-02-2013, 08:57 PM   #14
Did you check the reset on the chimney with the 2 red wires going to it?
Old 05-02-2013, 08:59 PM   #15
VinceU's Avatar
Do you have at least door lights? If not you aren't you have no power supply to the box. If you have lights could be board., but at this point it becomes expensive troubleshooting to randomly change parts. Suggest a Dometic mechanic to help, any good RV shop.
Old 05-02-2013, 09:05 PM   #16
No door lights...not aware of a reset at the chimney....but I'll see..back in a minute....
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:09 PM   #17
Start resetting all the GFCI outlets.
Old 05-02-2013, 09:14 PM   #18
OldCoot...
You da man!!!
I had looked everywhere for some type of reset or something but my frig had the recall and when they rewired the reset was covered and you had to look hard to find it...We got power now!!
Thanks so much!! How much is a service charge from NC to Ga!!
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:16 PM   #19
I had checked the GFIC first, then the blade fuses in the inverter, next the breakers in the inverter. I made sure there was power to the outlet behind the refrig...I had checked it all I thought...
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:16 PM   #20
TURBS's Avatar
OldCoot...
You da man!!!
Case of BBC'S! :ROFLBLACK:
