Old 05-02-2013, 09:18 PM   #21
Any idea what makes that reset button kick out? Think that will be a continous problem?
06 Rockwood 8285SS
97 Z71 Chev
Firestone Air Rides(thanksYouroo)
2010-33 nites
2011-41 nites and growing
2012-29 with more to come
kscr4 is offline   Reply With Quote
Old 05-02-2013, 09:19 PM   #22
Originally Posted by kscr4 View Post
OldCoot...
You da man!!!
I had looked everywhere for some type of reset or something but my frig had the recall and when they rewired the reset was covered and you had to look hard to find it...We got power now!!
Thanks so much!! How much is a service charge from NC to Ga!!
Glad to be able to help. Turbs wants a case of BBC delivered to Goshen rally.
Me, I'll take a cup of coffee.
Old 05-02-2013, 09:19 PM   #23
VinceU's Avatar
No door lights...not aware of a reset at the chimney....but I'll see..back in a minute....
The chimney switch causes control to shut down for elec or gas to stop because of chimney overheating. If no lights you have no 12VDC being fed to the terminal board, proceeds through the fuse you checked and into lights and door switch. You probably have not panel control inside, Led or LCD controls. If this is the case the power from the fuse panel is not reaching the reefer. Bad supply fuse or loose connection enroute. Time for a voltmeter and check for power at the terminal strip input, the output of the fuse panel etc. You're getting warmer......
Old 05-02-2013, 09:21 PM   #24
VinceU's Avatar
Good shoot Coot, 2nd chimney switch this week.
Old 05-02-2013, 09:34 PM   #25
I guess I need a chimney sweep...huh...
Thanks guys for all your help!!
VinceU you lost me...but that's not hard to do...
Once again THANKS TO ALL!!!
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:38 PM   #26
SYE
SYE's Avatar
Did you check the reset on the chimney with the 2 red wires going to it?
I must ask, what is the chimney for the fridge. Is it a vent to the roof. Mine is in a slide so I do not have one of these.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 05-02-2013, 09:41 PM   #27
Yours has one also, it is the vent for the gas burner and goes out the vent above and behind the frig.
Old 05-02-2013, 09:44 PM   #28
SYE
SYE's Avatar
Ok thanks, I have always heard it called an exhaust vent., By the way my package arrived today, thanks they look nice. Now to find matching paint for the awning. Thanks again.
Scott & Vicki
Old 05-02-2013, 09:46 PM   #29
...By the way my package arrived today, thanks they look nice. Now to find matching paint for the awning. Thanks again.
Hope they meet your expectations and let you enjoy your awning more. Post some pictures. Thanks for the business.
Old 05-02-2013, 10:00 PM   #30
VinceU's Avatar
The chimney (RV reefers) is the heat source for the refrigerant, in the Chimney the 120 volt elements are housed and at the bottom the gas burner. Either one or the other heats the gas in the tubing inside, the heat and exhaust cools as it goes up and exhausts into the roof vent or in your case the upper vented door of the fridge. The lower vent door allows cool air to cool the remaining components of the back of the fridge, the condenser at the top of the heap. The cooling air and the hot gas exhaust together at the same place.
