Old 05-01-2013, 08:42 PM   #1
Dometic RV Refrig...
This past Sunday I unplugged our camper from shorepower due to an approaching thunderstorm. Late this afternoon I plugged it back in and a short while later I checked the frig and no power. There is power to the recepticle behind the frig. I checked all fuses I could find, none blown. The slide out and the interior lites work fine. The only thing that could have possibly drained the battery was the propane detector.
If the battery is low, the converter should charge the battery back. If so how long would it take.
Any ideas why there is no power?
06 Rockwood 8285SS
97 Z71 Chev
Firestone Air Rides(thanksYouroo)
2010-33 nites
2011-41 nites and growing
2012-29 with more to come
kscr4 is offline   Reply With Quote
Old 05-01-2013, 09:25 PM   #2
VinceU's Avatar
If you have interior lights, unless you added AC lamps, the balance in ceiling in bath etc are 12VDC if they are working you have battery power.
In the fridge my drawing shows one 12VDC and one 120VAC fuses in the external control board where the coils outside panel is. There may also be one or two in external wiring in-line style. Check all these before you go any farther.
Old 05-01-2013, 09:29 PM   #3
I'll go back and check the outside ctrl panel. I checked and saw one fuse that was ok but I must have overlooked the other fuse...
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 08:00 AM   #4
VinceU's Avatar
Those two are under black PCB cover.
Old 05-02-2013, 08:04 AM   #5
TURBS's Avatar
In here.
Old 05-02-2013, 08:05 AM   #6
TURBS's Avatar
Under this cover
Old 05-02-2013, 08:48 AM   #7
SYE
SYE's Avatar
Originally Posted by f1100turbo View Post
Under this cover
Attachment 29456
Ron, Have you got any pics or a copy of the like to the thread of your refrigerator fans that you installed
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 05-02-2013, 08:52 AM   #8
TURBS's Avatar
Pm sent
Old 05-02-2013, 09:05 AM   #9
A surge protector would have eliminated the need to "unplug"....just a thought
George
ynott96 is offline   Reply With Quote
Old 05-02-2013, 09:25 AM   #10
Thanks Turbo...
I checked that one and saw the horizontal fuse but in my haste I overlooked the smaller vertical fuse...it will be later today before I can get back in there...
That pict looks exactly like my set up...
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:27 AM   #11
TURBS's Avatar
Thanks Turbo...
Post back what you find.
Old 05-02-2013, 09:28 AM   #12
TURBS's Avatar
George
Was thinking the same lol.
But most likely would not help on a direct lightning strike.
Old 05-02-2013, 08:41 PM   #13
I checked both fuses and they look like they are good..the wire element was intact on both...I'll change them both on Friday while I have it apart. Will the control panel go bad...I have the Dometic factory book but it doesn't really help in this situation.
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 08:57 PM   #14
Did you check the reset on the chimney with the 2 red wires going to it?
Old 05-02-2013, 08:59 PM   #15
VinceU's Avatar
Do you have at least door lights? If not you aren't you have no power supply to the box. If you have lights could be board., but at this point it becomes expensive troubleshooting to randomly change parts. Suggest a Dometic mechanic to help, any good RV shop.
Old 05-02-2013, 09:05 PM   #16
No door lights...not aware of a reset at the chimney....but I'll see..back in a minute....
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:09 PM   #17
Start resetting all the GFCI outlets.
Old 05-02-2013, 09:14 PM   #18
OldCoot...
You da man!!!
I had looked everywhere for some type of reset or something but my frig had the recall and when they rewired the reset was covered and you had to look hard to find it...We got power now!!
Thanks so much!! How much is a service charge from NC to Ga!!
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:16 PM   #19
I had checked the GFIC first, then the blade fuses in the inverter, next the breakers in the inverter. I made sure there was power to the outlet behind the refrig...I had checked it all I thought...
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 05-02-2013, 09:16 PM   #20
TURBS's Avatar
OldCoot...
You da man!!!
Case of BBC'S! :ROFLBLACK:
