Old 07-30-2012, 02:56 PM   #1
dometic single zone thermostat
e2 error message flashes on the thermostat of my roadtrek (2013, 170, versatile)
after researching over the weekend i learned that dometic is aware of this flaw. basically if inside temp. is too high (or too low) some sensor stops working and only fan will work.
someone suggested keeping a ziplock bag filled with ice near the thermostat to cool it down. this worked for me. i had to cool the thermostat for approximately 5 minutes.
my question is if dometic knew/knows about this issue why not fix the thermostat specially in it's newer models?
i still have to take my rv to the dealer to get the thermostat replaced.
using a ziplock with ice worked momentarily only. ac stopped working after a while and E 2 error message started flasing again.
nsv2012 is offline   Reply With Quote
Old 08-06-2012, 10:41 PM   #2
I have the same problem with my 2011 blue ridge. I usually either open windows and turn on all exhaust fans or set air early and let it run all day before inside temp gets to hot
Blueridge40 is offline   Reply With Quote
