Old 04-05-2014, 06:19 PM   #1
veggiesnvino's Avatar
Dometic single zone thermostat Malfunction
On our Dometic single zone LCD thermostat all the operating lights ( fan, cool & furnance) are all lit up. The digital temperature readout will not come on. And the controller will not turn on the air,fan or furnace.
Any suggestions?
Tried taking out the fuse at fuse box let it sit for 5 minutes and turned back on. No dice all the lights lit up and won't operate.
Mike & Karen King
2012 Crusader 320rlt
veggiesnvino is offline   Reply With Quote
Old 04-06-2014, 08:39 PM   #2
Take off the thermostat. just pull on it. There may be a fuse under the cover.
Priusron is offline   Reply With Quote
Old 04-06-2014, 10:18 PM   #3
Pulled off the cover. Did not see a fuse. Just a circuit board
Mike & Karen King
Old 04-06-2014, 10:37 PM   #4
Then you need to reset it. Disconnect the power cord so the converter won't feed it power. You can just trip the breaker for the converter and a.c. if you want. Disconnect 12 volt power. This can be done with a switch or by subjecting the battery. Reconnect everything. If that doesn't work replace the thermostat. Hehe you checked your 12 volt fuses?
Old 04-06-2014, 10:48 PM   #5
Ok. Thank you Priusron.
Will try plan B.
I checked the fuses, but will indeed take another look.
Thanks for giving me some suggestions before I replace it.
Mike & Karen King
Old 04-07-2014, 09:01 PM   #6
Well, tried it all....
We will need to buy a new one.
Thanks for the suggestions.
It was worth a try
Mike & Karen King
Old 06-24-2014, 11:56 AM   #7
billybeer's Avatar
I was wondering what you meant by buying a new one. Are you talking the thermostat? Just wondering I'm having a similar problem. Also wondering if you did it and it actually fixed it.
thanks.
2011 Avalanche
2012 Shamrock 23SS
billybeer is offline   Reply With Quote
Old 06-25-2014, 11:50 AM   #8
We replaced the wall thermostat. We went down to our local RV supply dealer, they had one in stock. It only took about 5 minutes to replace... A couple of wires is all, and presto change-o.....we were back in business!
Mike & Karen King
dometic, thermostat
