Old 04-13-2011, 04:09 PM   #1
Wildwood1's Avatar
dometic start up
sometimes my fridge (dometic) doesnt want to start when i switch to propane! i dont know if it is a coincidence or not but if i preheat the thermo coupler tip (outside behind fridge access door) with a match it seems to start fine. if i dont preheat i can hear the fridge trying to ignite and after a few attempts it stops and the "check" light comes on.
is there anything that i can check or maintain to get it to start better, other than bringing it to the rv money man
Wildwood1 is offline   Reply With Quote
Old 04-13-2011, 05:04 PM   #2
Send a message via Skype™ to scubieman
I think you can replace them. Attempt that maybe.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 04-13-2011, 05:16 PM   #3
Wildwood1's Avatar
maybe that would be the first thing i should replace - it probably isnt that expensive ( who we kidding ) i didnt mention before but sometimes it does start on its own but more often than not i have to persuade it to cooperate.i'll get a price on the thermocoupler and start from there!!
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
Old 04-13-2011, 05:17 PM   #4
grhodes50's Avatar
If you haven't ran any gas appliances there may be air in the line. It could take a few attempts to get all the air out. You can use the range to get the air out. Once it lights up the rest (water heater, furnance & refrig) should work as well.
I had to do this with the tt's I previously owned. The trailer I have now is the only one that seems to hold gas in the line between trips.
Not sure if this is what you are experiencing, but I hope this helps.
Gary & Trish
2018 Nights Camped - 5
Old 04-13-2011, 05:18 PM   #5
Actually on second thought it could be something else. I know most fridges when they start up there is somethign to make the pilot hot before trully turning on to start doing it's just. It could be the pilot or the electric pilot starter. I would have somone switch it on and watch and possiblity get a better idea before replaced anything. I know if the pilot does not get hot enough it will not start a flame.
Old 04-13-2011, 06:54 PM   #6
prof_fate's Avatar
We have a gas fireplace (not an expensive one) and one fall it would not start up - the pilot would not stay lit and I figured it was a bad thermocouple. A bit of googling looking for service/parts turned up an interesting tidbit - soot / carbon builds up on the thermocouple and acts like insulation so it never gets hot enough. A bit of cleaning with some fine sandpaper and it works like new.
May not be your issue, but it's a no cost solution to try. Could be the match is hotter or burns off just enough soot for it to work.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-13-2011, 08:20 PM   #7
sherdep's Avatar
we must be on the same page - thats what i was thinking -
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-13-2011, 08:23 PM   #8
Herk7769's Avatar
All right, here is where knowing what model and year your camper is will help a lot. (Shameless plug for putting such info in your signature)
There was a huge recall of Dometic Refrigerators that added stack shields. If your fridge is in the serial number block, the lack of covers could cause pilot blowout in windy conditions.
HAM CALLSIGN - KC3FFW
Old 04-13-2011, 08:30 PM   #9
sherdep's Avatar
Originally Posted by herk7769 View Post
All right, here is where knowing what model and year your camper is will help a lot. (Shameless plug for putting such info in your signature).
can always laugh at some of your posts Lou BTW keep up the good work
Old 04-13-2011, 08:51 PM   #10
Wildwood1's Avatar
my signature now has it !!!! however i dont think the wind is the issue because i start it up at home (no wind at all) before we head out . once its going it works really well.
Kevin and Joanne
