Old 03-30-2018, 06:42 PM   #1
Dometic Thermostat
The blower fan won't turn off and the igniter keeps clicking and won't light my furnace. The green light that used to be on is no longer lit on the thermostat (see attachment). Does anyone have one of these thermostats? Could it be a bad thermostat? The coach is only two years old. Thanks.
TDLucas is offline   Reply With Quote
Old 03-30-2018, 06:46 PM   #2
ejohnson1144's Avatar
The green light should come on when you push the mode button . are your batteries charged
ejohnson1144 is offline   Reply With Quote
Old 03-30-2018, 06:47 PM   #3
What have you checked or tested?
Do you have propane?
Is it turned on at the tank?
Have you checked for blown fuses?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 03-30-2018, 07:01 PM   #4
Here is some info
Old 03-30-2018, 07:30 PM   #5
Batteries and propane are fine. I disconnected and reconnected the wires. The green light came on for a few seconds then went off. No display in the window. The large silver thing at the top (resistor?) is hot.
Old 03-30-2018, 07:48 PM   #6
That's a capacitor
Old 03-30-2018, 07:49 PM   #7
You may have a bad thermostat
Old 03-30-2018, 08:43 PM   #8
Just as confused as you
Scrapper's Avatar
I would go with what ejohnson1144 said about a bad thermostat.
The round silver thing is a capacitor, if it is hot then it has an internal short. Given enough time it will start leaking at the cross etched on the top, sometimes they will explode with a bang like a gunshot.
Several years ago there was batch of capacitors that had the formula of the paste inside messed up and installed in desktop computers. I happened to have had one of those motherboards, 5 capacitors leaked, 1 exploded loud enough the next door neighbor heard it.
Richard & Jill
Old 03-30-2018, 09:12 PM   #9
Bad Thermostat
Thanks everyone. These thermostats are hard to find. Is there another brand or model that controls the three functions, or am I stuck with this model?
Old 03-31-2018, 08:22 AM   #10
Bill and Gail's Avatar
Coleman-Mach is another brand. You have to be sure it has the right functions. Your rv parts dealer should have a catalog. They are usually listed under appliances in the catalog.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
Bill and Gail is offline   Reply With Quote
Old 03-31-2018, 08:35 AM   #11
Here's one on Amazon...
Dometic Single Control Kit LCD Cool Furnace Thermostat 3313189.015 Black https://www.amazon.com/dp/B00CWFY4RG..._U34VAb49CE8GV
Old 04-01-2018, 08:05 AM   #12
This is the updated version;
https://www.amazon.com/Dometic-33162...G0PMEKFAFB57D7
Coachman Freedom Express 320BHDS
Super 8 is offline   Reply With Quote
Old 04-01-2018, 08:54 PM   #13
I have the one linked above. It has a nice blue backlighting when pressed that goes off after 10 seconds or so after last touched. Very useful for night when others are sleeping.
Edit: Grrrr, I swear it was not sideways when I hit submit....
ProCharger is offline   Reply With Quote
Old 04-04-2018, 02:40 PM   #14
I got a new one from Dometic. Works great.
Old 04-04-2018, 03:53 PM   #15
Thanks for letting us know that you got a new one and that fixed your problem.
Gotta go campin!
dometic, thermostat
