Old 12-31-2015, 10:20 PM   #1
R3Jones's Avatar
Dometic Thermostat Issue
I have a Dometic Brisk Air II with single zone thermostat. When placing the fan in "Lo" mode it shuts off when the desired temperature is reached but it should remain on. When the fan is placed in "Hi", it remains on and acts as it should. Anybody else have this issue? Do I have a bad thermostat?
Also, I've tried resetting to factory defaults with the same results.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 01-01-2016, 05:25 PM   #2
Head Rambler
It sounds like a bad t-stat.
What happens when it's in auto?
Did it just started doing this?
Gotta go campin!
Old 01-01-2016, 07:06 PM   #3
R3Jones's Avatar
Seems to work correctly in auto mode. It just started doing this and I'm not sure if I caused it or just bad luck.
I recently installed a hard start capacitor but I don't think the issue is related.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
Old 01-01-2016, 11:33 PM   #4
MNtraveler's Avatar
Yeah, LOW should stay on, not cycle.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 01-09-2016, 10:12 PM   #5
tmfaulksr's Avatar
Originally Posted by R3Jones View Post
I have a Dometic Brisk Air II with single zone thermostat. When placing the fan in "Lo" mode it shuts off when the desired temperature is reached but it should remain on. When the fan is placed in "Hi", it remains on and acts as it should. Anybody else have this issue? Do I have a bad thermostat? Also, I've tried resetting to factory defaults with the same results.
-R.Jones
Nitro 31FQSL
though i do not have an answer
i recently had a question of operation with my A/C in relation to the thermostat on my 2015 Puma. i emailed Puma and they responded within 24hrs with an answer to my question. that may be an option that could give an idea of what is happening that may not have been considered...
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 01-09-2016, 11:18 PM   #6
HONDAMAN174's Avatar
Try re initializing the t-stat. In the off position, and with the little LED light off, press and hold + & on/off for about 5 seconds or until -- appears.
I had to replace my t-stat today because static electricity took out my lcd screen when I went to make an adjustment. So- touch something metal before you touch that stat.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-09-2016, 11:25 PM   #7
R3Jones's Avatar
Yeah I tried that as well. Seems the t-stat went bad.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
dometic, thermostat
