Old 04-02-2019, 11:32 AM   #1
Dometic Thermostat Problem
I have a Dometic T'stat (3313189.000) in my trailer that is acting up. If I have it set on heat it cycles just like it is supposed to. If I have it on AC it will run one cycle and then IF the t'stat is satisfied it will not turn the AC on UNTIL we either turn the t'stat off OR if I short the temperature sensor it will run a cycle again. I am thinking that the t'stat needs replacing, but not real certain. I have checked for a replacement, but run into this:
The Dometic 3313189.000 is now obsolete by the manufacture. Dometic recommends replacing this thermostat with the Dometic 3316230.000.
Am I on the right track? Years ago I used to work on HVAC systems (residential and commercial) but those were the old analog controls.
Tom
2005 Dodge Ram
2017Salem Hemisphere 346RK
MnTom is offline   Reply With Quote
Old 04-02-2019, 11:58 AM   #2
Multi-Slacker
Just for clarity, you are saying that the A/C will not cycle even if the temp is above the set point? How far above does it get before you manually restart or short?
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is offline   Reply With Quote
Old 04-02-2019, 12:11 PM   #3
Head Rambler
Have you tried initializing the thermostat? If not, it's worth a try to see if it helps.
There have been reports of that happening and the problem was the control board in the A/C.
Gotta go campin!
Old 04-02-2019, 12:17 PM   #4
Guess I forgot a couple of things....I have re=initialized the t'stat and tried setting the differential to 1 degree instead of two degrees.
CurtPutnam, the space temp will climb as high as I let it without doing anything.
Bama Rambler, I have heard of that too, but trying to properly diagnose the issue instead of throwing parts at it........
2005 Dodge Ram
dometic, thermostat
