Old 10-09-2014, 06:40 PM   #11
ColoradoRick's Avatar
Wow, we have a new trailer and the Dometic Model 300 toilet, also, was shooting water over the lip.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-13-2014, 09:23 AM   #12
krhthm
Yep, They tell you to use plyers to bend the tabs down on either side of the jet. Well, they tried that at the shop, and I've done it. Mine still shoots water all over the place. I've learned to manipulate the pedal, but it still hasn't solved the problem. It's just a terrible design!!! For my last attempt, I'm going to add a larger piece of plastic above the jet. I'm thinking I will use some epoxy to hold it in place.
Keith & DeAnne
2008 Ford F150 4X4
2013 Rockwood 2304s
11 nights camped in 2014
krhthm is offline   Reply With Quote
Old 10-13-2014, 03:11 PM   #13
I'm thinking my problem was the weight of our big slide out making the trailer lean just enough that way to make the water flow up and over the lip of the toilet. (It doesn't overflow with the slide in) have you tested yours?
Rick & Karen
Monument, Colorado
Old 10-13-2014, 03:43 PM   #14
krhthm
Certainly could be the problem in yours. However, mine sprays out so fast it doesn't matter what angle the trailer's at, it will still spray out of the bowl.
Keith & DeAnne
2008 Ford F150 4X4
2013 Rockwood 2304s
