Old 02-23-2013, 10:54 PM   #1
krhthm
dometic toilet problem
I've searched for for this problem, with no success.
I have a 2013 rockwood. We've had it out twice. When you first activate the flush pedal the water sprays so hard it shoots out over the rim. Once the peddle is down farther, it stops spraying over. At first I thought my water regulator was allowing too much pressure, so I unhooked and used the on-board pump. still the same problem.
I've seen posts about leaks and installation, but have found nothing like this. Any ideas
Thank you,
Keith
Keith & DeAnne
2008 Ford F150 4X4
2013 Rockwood 2304s
11 nights camped in 2014
krhthm is offline   Reply With Quote
Old 02-24-2013, 04:39 AM   #2
H2oski
It sounds like there maybe some manufacturing debris partially clogging some of the holes. Try using a piece of a clothes hanger to dislodge any debris in the hole that sprays.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 02-24-2013, 06:32 AM   #3
Oakman's Avatar
Sorry, I don’t have a fix for you. I have the same problem. I believe Dometic calls this model their powerflush, swirl-jet bowl. We have an all-in-one bathroom so before I flush I turn on a water faucet at the wash basin to reduce the water pressure and then flush. I’m glad you brought this issue up because it reminded me to have the service personnel at the FROG rally look at this.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-24-2013, 07:12 AM   #4
Herk7769's Avatar
Repairing a Thetford Aqua Magic V
This is how I repaired my Thetford for a low/no flow flush problem and it will give you an idea of how the valve works.
It does sound like an overpressure problem since once the valve opens the pressure drops to a proper amount.
HAM CALLSIGN - KC3FFW
Old 05-06-2013, 02:43 PM   #5
Dometic Toilet Problem
I have had contact with Dometic and they say to bend down the "ears" on the valve that is at the back of the toilet. I am attaching a .pdf that shows how to fix this with pliers. We will try this next weekend. Good luck.
Lisa
ingll01 is offline   Reply With Quote
Old 05-06-2013, 02:47 PM   #6
Triguy's Avatar
Here is Lisa's picture from that PDF ...
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-10-2013, 05:43 AM   #7
Oakman's Avatar
I wish the solution for my Dometic model 310 toilet was that simple. I guess I'll quit procrastinating and send Dometic an email about the problem.
Bob and Joyce
ATU Local 788
Old 05-10-2013, 09:02 AM   #8
Fulltime family RVer
They are really easy to get ahold of by phone. No extended phone tree or anything like that.
ependydad is online now   Reply With Quote
Old 05-10-2013, 09:09 AM   #9
Iggy's Avatar
I had a Dometic 310 and the big valve quit closing all the way and it was clean.
Called them and told them the problem and gave them model and serial number and they sent me a new complete toilet. I installed it myself in a few minutes.
You need to call them
Old 05-10-2013, 09:24 AM   #10
Oakman's Avatar
I was hoping for an easy fix. If it's toilet replacement I might not do that. The water shooting over the rim is inconvenient but also inconsistent. I will be calling Dometic today to see what they tell me. If they send a new toilet maybe I'll just bring it to Goshen and see if I can get FR to install it.
BTW, thanks for the heads up about calling instead of sending an email.
Bob and Joyce
ATU Local 788
