Old 04-26-2013, 02:49 PM   #1
Dometic - UGH !!!! -warranty/troubleshooting issues.
I bought a brand new fifth wheel last December. Just took it out for the second time last weekend. The refrigerator would not work. I went thru the troubleshooting guide, did everything in it. Which wasn't much I could do.. check the gas, check the electric to it, other than that, shut it down and get it serviced... cost me $180 to find out it has a reset switch and after that, it worked. Since there wasn't anything wrong with the fridge, no warranty coverage.. But, since I did everything the manual said, I feel I should be reimbursed. They feel otherwise. No parts under warranty were not replaced.
PODGE is offline   Reply With Quote
Old 04-26-2013, 03:15 PM   #2
Ouch! That would be my luck.
Len & Cheri is offline   Reply With Quote
Old 04-26-2013, 03:47 PM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
On the bright side...you will be repaid in gratitude when someone else on this forum has the same problem & you can advise on the fix!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-26-2013, 03:49 PM   #4
fonzie's Avatar
X2 pay it forward
Fonzie
Old 04-26-2013, 03:55 PM   #5
I hope they showed you where the reset button was!
Old 04-26-2013, 04:01 PM   #6
TURBS's Avatar
I'd actually like to know the model of fridge.
If it actually has a reset the manual should show it.
Turbs
Old 04-26-2013, 04:02 PM   #7
Did you take it to the dealer you bought it from? If so, I would not have paid them a
2 hours ($90 @ hour) labor charge just to reset a switch or a breaker. It should have been pointed out to you when you purchased it the RV, and it should be in the owners manual.
jamesroadking is offline   Reply With Quote
Old 04-26-2013, 04:12 PM   #8
VinceU's Avatar
Turbs
Dometic manuals leave a bit to be desired sometimes but X2 with Turbs what fridge and where is it? Others recently may have the same problem...
Old 04-26-2013, 04:15 PM   #9
Herk7769's Avatar
I am curious as well. What reset switch?
Name:	Circuit diagram.jpg
HAM CALLSIGN - KC3FFW
Old 04-26-2013, 04:17 PM   #10
Herk7769's Avatar
I would put this in the "Ripped off by dealer" column...
