Old 08-24-2015, 07:34 PM   #1
ElShamardo's Avatar
Dominguez Refrigerator issue
On our second trip out with our new 3029 windjammer the freezer worked fine but the refrigerator would not cool. The trailer was level and I tried it on both propane and electric with no change. I was plugged into 50amp. And had good power to it and the 12v was at full power too.
I let it run for about 24 hours and it started working. Any thoughts on why the delay in cooling?
ElShamardo is offline   Reply With Quote
Old 08-24-2015, 07:39 PM   #2
KyDan's Avatar
It's probably a dometic not a dominguez??
It's always a good idea to turn on the fridge 1 day before you plan to use it.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 08-24-2015, 07:39 PM   #3
Flybob's Avatar
If you are referring to the Dometic fridge, it takes a while to cool. Start it the day before you leave and allow to cool overnight, Then put only ( or at least mostly) cold food in it and you will be fine. Replace drinks as used rather than all at once as it takes much longer for this type of fridge to cool food and drinks.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-25-2015, 08:13 AM   #4
ElShamardo's Avatar
Love spellcheck... It is. Thanks.
James & Kathi
Trailer: Rockwood 8299-BS 5th Wheel
Truck: Ford F250 4WD 6.7L King Ranch
Austin Texas - Live Music Capital of the World & Home of the Longhorns!
Old 08-25-2015, 09:08 AM   #5
TURBS's Avatar
The fridge and freezer is all one unit, therefore if the freezer is working so is the fridge.
http://home.howstuffworks.com/refrigerator5.htm
http://www.cs.cmu.edu/~mnr/fridge.html
http://www.fmca.com/polks-top-7/2633...fficiency.html
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-25-2015, 09:16 AM   #6
Flybob's Avatar
A fridge works by removing heat energy from the contents. RV fridges are nowhere near as efficient as your home fridge so extra care is needed. Cold air has very little ability to absorb heat energy so an empty fridge will heat up quickly if warm items are added. A fridge full of cold items will be most efficient. Once the fridge is cold add cold items and it will stay cold. If you need to add warm items, add them over a period of time to allow fridge to catch up. Adding a small internal fan to circulate air helps. RV fridges work very well if used properly.
TST Tire Monitors
2 100W solar panels
Old 08-25-2015, 11:38 AM   #7
Jane1550's Avatar
Elsewhere I posted a few tricks we have used with success. Spousal unit modified ducting to improve air flow and added 3 - 120mm computer fans to force air over the coils. Cools down in 4 hours instead of 24. I also got a small fan to place inside reefer to improve air flow, freezer maintains 0* and reefer 37*
Jane1550 is offline   Reply With Quote
Old 08-28-2015, 08:17 AM   #8
Cajun Style's Avatar
http://youtu.be/oIJYx5j2nPQ
This might help Ford has video from 1 to 20 you can learn a lot
I did everything to my Fridge and in 8 hours it's around 40 Deg. In fridge
12 hours it's down to 32 deg. I also put a fan on the outside under the coils blowing up
And a fan on the inside circulating and changed the thermistor on side with a snip the tip
Model.
Cajun Style is offline   Reply With Quote
Old 08-28-2015, 08:22 AM   #9
http://www.rvwholesalers.com/parts/p...nt-fan-72-8401
http://www.snip-the-tip.com/
Old 08-28-2015, 08:25 AM   #10
http://www.ebay.com/itm/Dometic-Refr...d78721&vxp=mtr
refrigerator
