Old 06-01-2014, 05:29 PM   #1
dcheatwood's Avatar
Dual a/c operation
Is this normal? When I'm running main a/c and not the bedroom a/c, I can feel cold air coming out of bedroom a/c return air vent, thru the filter. Surely that can't be normal as any dust captured in the filter is blown out onto the bed.
from David's RAZR M
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-12-2014, 07:47 PM   #2
Plain Old Member
Somewhat normal, yes. Think of it this way. Common duct system between the 2 AC's. Rear AC running, air goes through the duct, into the discharge ducting of the front AC, through the cage fan, through the coils and out the intake. Nothing really to stop the air from going that way, unless front is on as well. Shouldn't be any huge amount of air, but a little no doubt will make it through there.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
