Old 11-21-2018, 07:17 PM   #1
DuoTherm 5 button thermostat
I have a problem with a 2006 Duo Therm 5 button thermostat. It was set to heat today and the AC unit attempted to engage intermittently will the furnace was on. When I checked the AC temperature setting, it was at 0. I turned the thermostat off and on and got the EE error. I reset it per instructions but still got the EE error. I checked both ends of the comunication wire and they looked fine. All fuses are good. Any ideas? Thanks.
merrykalia is offline   Reply With Quote
Old 11-22-2018, 07:03 AM   #2
Head Rambler
Error EE is a communication error, but having said that, the error could be the stat, control board, or the cable. You can try removing power for a few minutes and then resetting the stat again.
Also, make sure that your battery is fully charged, because they will give that code sometimes on low voltage.
Gotta go campin!
thermostat
