Old 04-21-2014, 09:24 PM   #1
DVD
We have a New2014 Solara 24R and are on the road to CA from the East coast and can not play a DVD on the Jensen radio we are doing what the manual list just ejects 5 secs after it's inserted any suggestions?
lee134 is offline   Reply With Quote
Old 04-21-2014, 09:32 PM   #2
wmtire's Avatar
Congratz on the new RV.
Are you needing help, or asking a question about maybe the DVD player?
EDIT: I see you edited your post, Hopefully someone will chime in.
2011 Flagstaff 831 RLBSS
Did you know, according to Google: Pepsi was once the 6th largest military in the world?
Old 04-21-2014, 09:33 PM   #3
Herk7769's Avatar
A copy or an original disk?
HAM CALLSIGN - KC3FFW
Old 04-22-2014, 08:17 PM   #4
Original from Redbox. Jensen tech support feels it might be. Hardware issue? There is a antena that was in the glove box, I do not know where it needs to be mounted because of the protruding over the cab bed
Old 04-23-2014, 05:41 PM   #5
camaraderie's Avatar
If the disc is popping out after 5 seconds...it is a dirty/scratched disc OR a failure in the unit that will require either service or replacement. Suggest you check with several other discs to see if you get the same pop out and if you do....pull it off and let jensen deal with it.
If it has been working fine to date...you might wanna buy & try one of these before pulling the unit out for the factory.
http://www.amazon.com/Maxell-DVD-LC-.../dp/B00000JPPI
camaraderie is offline   Reply With Quote
dvd
