Old 06-10-2012, 06:02 PM   #11
Herk7769's Avatar
Originally Posted by cherry1 View Post
video cable, looks factory installed.
Can you tell if it is a single yellow RCA type connector or does it have a connector that looks like a computer cable?
The one that looks like a computer cable should carry your color ad sound signals to your TV. The yellow RCA type cable has the B&W signal and color information together on the one wire (the red and white are for stereo sound).
HAM CALLSIGN - KC3FFW
Old 06-10-2012, 06:36 PM   #12
rca yellow. there is no red or white cables sound comes thru surround sound. i have a zx75 combo thing mounted above tv
cherry1 is offline   Reply With Quote
Old 06-10-2012, 06:54 PM   #13
Herk7769's Avatar
Your picture setup could be wrong.
Try other settings under "video" such as YUV TV
S-Video is not correct for a yellow RCA plug.
If none of these setting work
You might try a different video output on the ZX-75 (there are 3 of them).
You can also try a new cable.
Old 06-10-2012, 07:39 PM   #14
looks like there is no remote, i cant access menu on zx75 will order one and try diffrent set up, will try different output and cable while waiing. thank you so much for your help. i will let you know how it goes
led pad
