Old 06-10-2012, 12:40 PM   #1
Dvd player
I Have a sunseeker 2250s le and the DVD player is part of the radio within the dash. With the ignition and engine off, I can play the radio or watch a movie. My question is- when I have it on, which battery is being used to power the radio or DVD player? Is it the truck battery or the coach battery? I'm always plugged in to a camp site so is the power coming from electricity or the battery. I just don't want to run my truck battery down. Thanks.
Sparkbark is offline   Reply With Quote
Old 06-11-2012, 06:34 AM   #2
Coachmen Adrenaline
The radio is powered from the battery control center in the side of the stepwell, getting its power from COACH batteries. The truck ignition, or turning the disconnect switch to ON, both give the IGN signal, allowing the radio to turn on. We designed it so you can't run down the truck batteries using the radio. When plugged in, you are getting power from the converter.
jamiller45 is offline   Reply With Quote
Old 06-11-2012, 09:29 AM   #3
Thank you for your response! In relation to the radio/DVD player,
Old 06-11-2012, 09:31 AM   #4
Thank you for your response. In relation to the radio/DVD player, is it supposed to come out easily? I can pull it out and push it back in. When it is in, it is on a slant but stays in place. Thanks.
Old 06-11-2012, 09:37 AM   #5
Coachmen Adrenaline
It should snap in place and be pretty steady. I know with some of the Chevy chassis, it can be a little harder to get it pushed all the way in to where it sits correctly
