Old 05-18-2014, 09:59 AM   #1
DVD player isn't working...what are we missing?!
We had no problem mounting the tv, hooked up the audio/video cables and the coaxial cable. We get regular tv channels just fine. But when we put in a DVD, we can HEAR the movie...just not getting a picture. The audio/video cables are plugged into the color-corresponding socket. The coaxial cable is screwed into the tv...and we've tried screwing the other end into both the satellite and the cable socket but no luck with either. Help!
theayers128 is offline   Reply With Quote
Old 05-18-2014, 10:12 AM   #2
Couple of things. Did you change setting on tv to the DVD? Also it could be channel selective. Some tvs are set up so you have to adjust back and forth.
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-18-2014, 10:14 AM   #3
Add on: maybe channels 3 or 4
Jerry. Vietnam vet.
Retired
Old 05-18-2014, 10:14 AM   #4
Yes...we assumed it would work similar to the one in the house, so we tried switching tv to input, aux, etc, then tried different channels. Still nothing. I'm sure it's something simple!
Old 05-18-2014, 10:19 AM   #5
Maybe the video " line in" to tv is not correct and or DVD must be "line out"
Jerry. Vietnam vet.
Retired
Old 05-18-2014, 10:35 AM   #6
Missing Link
cyclepuck's Avatar
I had the same problem last year. Come to find out I used the wrong input on the TV. There was a 90 adaptor that was a different color than the cord which mixed me up.
Sent from Droid Ultra
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 05-19-2014, 06:38 AM   #7
Herk7769's Avatar
I am thinking the same thing. You might have plugged the yellow video output from your DVD player to the COMPONENT input on the TV instead of the AV (Composite) input.
HAM CALLSIGN - KC3FFW
Old 05-19-2014, 10:53 AM   #8
We have a Jensen system with three connections red/white and yellow. The red/white are for audio FROM the TV into the Jensen. The yellow was video (DVD) FROM the Jensen to the TV. My TV set had no yellow jack. Instead it used the green jack of the component jacks for video input.
Screwiest setup I had ever seen before.
Hope this helps.
2014 Coachmen Catalina 273DBS
50th Anniversary model
acope is offline   Reply With Quote
dvd
