Old 06-17-2013, 09:18 PM   #1
Hybrid_Lvr
Roo5008's Avatar
DVD plays black & white only
I found a thread from 2012 but there was no fix. TV plays normal color picture unless we put in a dvd then picture is black & white and grainy.
Anyone find a solution for this problem yet?
Thanks.
Tom and Missi, 2 girls, one Marty dog
2013 233s Roo, 1997 Chev Tahoe
Roo5008 is offline   Reply With Quote
Old 06-17-2013, 09:27 PM   #2
howellma's Avatar
Yes, i had same problem. Go into tv setup there is a different type of video to select, not the hd version if i recall, belive i had same post! Dont select color stream
howellma is offline   Reply With Quote
Old 06-17-2013, 09:29 PM   #3
Powerblast's Avatar
Could be a loose connection. Check outputs on DVD and inputs on Tv. It would help to know if your using aux input or playing the DVD on a channel - normally 2 or 3.
Powerblast
Virginia Beach
2007 Tocoma / 20013 SP-240 BR
Powerblast is offline   Reply With Quote
Old 06-17-2013, 09:30 PM   #4
DDC
DDC's Avatar
Must be a retro unit, sorry that was my first thought, this sounds like just a bad connection.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 06-17-2013, 10:42 PM   #5
jtstromsburg's Avatar
Yup. You probably have RCA connections hooked up component in, instead of stereo l/r and video. Look at the rear if the DVD player and then the TV. Should fix it easy.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 06-17-2013, 11:06 PM   #6
Herk7769's Avatar
This is exactly your issue. Plugging a composite RCA video (yellow RCA plug) into the component input of your TV will give you a black and white picture.
HAM CALLSIGN - KC3FFW
