Old 09-10-2016, 09:34 PM   #1
DVD stops when we use water pump
When we are watching a dvd movie using the IRV34 and someone uses the water pump(sink, toilet, shower) the dvd pauses or it goes blue on the screen. When you stop using the water pump the picture comes back up sound never is lost the whole time just the picture anyone know how I can fix this? It never did it before it started a month ago
2016 mini lite 2306
2012 Chevy traverse
Locchamp is offline   Reply With Quote
Old 09-11-2016, 07:47 AM   #2
Do you only have 1 battery. It is your amp draw from the pump.
JohnVtx is offline   Reply With Quote
Old 09-11-2016, 08:09 AM   #3
Head Rambler
Sounds like either you have a grounding problem or a coax shielding problem, or maybe both.
It could be a battery problem, but if it were, I'd expect to see lights dimming and the pump struggling.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-11-2016, 08:09 AM   #4
I have two 6v batteries so shouldn't be that
2016 mini lite 2306
2012 Chevy traverse
Old 09-11-2016, 10:14 AM   #5
NMWildcat's Avatar
2016 mini lite 2306
2012 Chevy traverse
Depends on their condition and charge status.... Or you could have gremlins
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-11-2016, 10:16 AM   #6
rattleNsmoke's Avatar
Maybe the water cooled DVD player is down on H2O?... In all seriousness, it sounds like your DVD player isn't getting full voltage. Try running an extension cord from the player to another outlet and that will isolate the electrical leg that might be the culprit.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 09-11-2016, 01:07 PM   #7
rsdata's Avatar
You do NOT know the exact status of your batteries charge if you do not own a cheap electrical meter that will measure voltage...
Harbor Freight or Walmart or any hardware store will have a meter for under $10 that you can use to measure the exact voltage of the batteries.
With the electrical cord unplugged from shore power...
Measure using the VOLTS function on the meter... Red lead to + battery terminal and black to - battery terminal
Each 6V battery should read at least 6.3 volts (12.6 volts from + of one to - of the other battery) with no load (nothing running on 12V). Then while running the pump, measure the voltage again and see if voltage drops from the no load voltage. Any drop more than 0.1 or 0.2 volts shows weak batteries.
If there is no voltage drop yet still have the DVD problem, then I would figure on a bad connection to the 12V line that the DVD works from.
I am going to bet that your batteries are weak, and the voltage drops below 12 V when the pump runs, which interrupts the computer that runs the DVD.
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
Old 09-11-2016, 06:08 PM   #8
mike.t's Avatar
It knew you were busy and it didn't want you to miss anything
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 09-11-2016, 06:58 PM   #9
I had a similar issue but with a inverter that was connected to the satellite feed (12v dc) that was used to power the inverter which was used to power the TV while boondocking. Apparently it is or was a voltage drop issue when the pump came on. My two batteries always carried the entire coach for the night without any issues but I did suspect that the wiring for the satellite feed seem to be rather small, perhaps 18 ga.
Walter & Anne
2013 Forest River Sun Seeker 3100SS
wogden is offline   Reply With Quote
Old 09-11-2016, 07:13 PM   #10
Flybob's Avatar
Check battery and ground connections. If one is loose you will have a high resistance connection and when current is drawn, the voltage will drop. Measure DC voltage at DVD with and without water pump. They should be almost identical.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
dvd, pump, water, water pump
