Old 01-14-2016, 12:10 PM   #11
I had to connect mine to TV with red white and yellow rca jacks to get mine to work.
noshowbobby is offline   Reply With Quote
Old 01-14-2016, 12:55 PM   #12
I had the same problem and it turned out to be that we weren't selecting the proper source.
David
David Providence is offline   Reply With Quote
Old 01-14-2016, 01:30 PM   #13
If all else fails do what I did - save yourself a lot of heartache and buy a DVD player at Walmart and use it instead. I am on my second RV. The DVD player in the first one gave out after 2 years. I have never even tried the DVD player in the second one as I have a "smart" DVD player that I hook directly to the TV via HDMI and enjoy that way. I have found that RV sound systems/all in one units are outrageously expensive and cheaply made. For instance, the replacement cost for my Concertone Genesis 3.0 is around $600.00. I paid less than $500.00 for my Sony 5.1 entertainment system at my house that is a lot more powerful and has more features than the one in the RV.
Middleburg Redneck is offline   Reply With Quote
Old 01-14-2016, 02:09 PM   #14
Iceman
DVD Not Working
Ran into the same issue. good suggestions above, with me it ended up being that the cables were falling out of the back of the player. Pulled it apart and reset (and rerouted them) the system worked correctly. Must have been the rough ride from the dealer.
rpjmartin is offline   Reply With Quote
Old 01-14-2016, 03:01 PM   #15
he said it was a cedar creek
ValMelton is offline   Reply With Quote
Old 01-14-2016, 03:26 PM   #16
Mr. Dan's Avatar
To whom are you speaking?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 01-14-2016, 05:53 PM   #17
RichL
Rich70's Avatar
Some asked if the dealer had it working. Is it possible you are using a BluRay when the unit only accepts DVDs? It's possible that the unit may not support BluRays.
Rich70 is offline   Reply With Quote
Old 01-14-2016, 06:26 PM   #18
DVD not playing
Thank you all, as soon as we can get to storage unit, we have a few options to try.
dmclaughln is offline   Reply With Quote
Old 01-21-2016, 08:24 PM   #19
My DVD player would not work. Dealer found one of the pins on the cables to the DVD was broken off to the DVD. Factory error. Replaced with new cable and all works now.
Charles Bibbs is offline   Reply With Quote
Old 01-21-2016, 09:40 PM   #20
I'll support this solution ----- my DVD player will not play BluRay. Regular DVD's work fine.
bruceatlam is offline   Reply With Quote
dvd, forest river
