Old 01-21-2016, 10:04 PM   #21
Have you tried running a cleaning disc thru it yet? I had a DVD player I thought was toast because it was simply very old. I ran a cleaning disc thru it and wahlah, like magic it worked great again. Dust and dirt on the laser really messes some units up. Now I like to use a bit of air duster before hand and then put the disc in to clean it.
getsum is offline   Reply With Quote
Old 02-02-2016, 11:26 PM   #22
bob dirt's Avatar
Originally Posted by bruceatlam View Post
I'll support this solution ----- my DVD player will not play BluRay. Regular DVD's work fine.
we found this to be the same problem
bob dirt is offline   Reply With Quote
Old 02-06-2016, 08:36 AM   #23
Was told by my dealer its a known problem and the whole IRV will have to be replaced, no fix
Ernest.M. is offline   Reply With Quote
Old 02-11-2016, 09:41 PM   #24
My Furrion system will not play Bluray DVDs. Try a regular DVD.
2015 3825FL Cardinal w Full Body Paint
2017 GMC 3500 Dually
South Texas
Biily is offline   Reply With Quote
Old 02-12-2016, 10:45 AM   #25
MNtraveler's Avatar
Have you checked if there is a parking brake interlock? If it is set, DVD will not play unless the brake is engaged. It's a safety feature n
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-12-2016, 04:00 PM   #26
Supposedly there is a "travel screw" that is inserted from the top of the unit that has to be removed. It's purpose is to keep the "guts" of the player from moving around while in transit from the player's mfg. The factory was suppose to remove it prior to installation in the trailer. Right or wrong, that is what I heard/read.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
dvd, forest river
