Old 06-01-2013, 05:49 PM   #1
howellma's Avatar
dvd will not show color
I have a 2013 solaire with the jensen stereo/dvd in it with Toshiba tv. for some reason we cannot get the dvd to play color anymore, or just cant remember if it was color??it appears to be hooked up per the instructions, just curious, its under warranty but dealer is 2 1/2 hours away, has anybody run across this before. we bought the tt Dec 8th.
howellma is offline   Reply With Quote
Old 06-01-2013, 05:57 PM   #2
Camping Buddys's Avatar
Is it connected via hdmi or rca?
If is rca, check the cables behind the tv, maybe a cable got loose.
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 06-01-2013, 06:00 PM   #3
jtstromsburg's Avatar
If its hooked up via RCA's, name sure you select a/v on input. I had a similar problem and realized the dw had selected component, which are different cords.
Worth a shot
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-01-2013, 06:06 PM   #4
Worth a shot
"Component" is still RCAs. It's just 5 of them instead of 3.
Old 06-01-2013, 06:08 PM   #5
True. But, I think most would understand...
Joel and Teresa
2016 Sabre 34TBOK
Old 06-01-2013, 06:40 PM   #6
howellma's Avatar
there are three connectors, but two go to aux ports, this is what the tv instructions saythe yellow from dvd goes to cvbs/y port
Old 06-01-2013, 07:09 PM   #7
If the tv have the rca yellow only conected is 'video' resolution 480 (composite), not component.
Make sure the tv is in video imput, not component or hdmi. Sometimes tv's have multiples video imputs.
Old 06-01-2013, 07:19 PM   #8
howellma's Avatar
BINGO! I went all the way back into the tv set up, there was an option to select video or colorstream hd, switched to video and presto!
Much!
Mike
