Greetings All, I know this is a revival of an old thread, but similar problem.
We have a brand new 2018 255RKS and out on our first trip with it. While getting it prepped the weeks prior to our departure, we had it in our driveway and would typically leave the fireplace on--even overnight for days. (Remember, just weeks prior to this, we had those 4 Nor'easters come through our area--trying to keep it warm to work on/in).
After the freezing temperatures lifted, I finally ran water through the system to flush the antifreeze out, and familiarize myself with the hot water heater.
Ever since then, the fireplace has occasionally started randomly popping the circuit breaker. The circuit breaker is a dual 15 amp breaker, and is also connected to the hot water heater.
The fireplace worked fine--uninterrupted--for days on end until the hot water heater was finally filled with water. Now, issues...
Why have the fireplace wired with the hot water heater? If I want the fireplace on, having priority over the hot water heater, I have to go outside to shut off the switch to the heater--which would likely mean it's cold out! This even happened last night whereas we had the fireplace on just to keep the chill out of the camper. But once the hot water kicked on at some point in the middle of the night, the breaker popped. So, we woke to a chilly camper AND water that was barely luke warm!
Anyone else experiencing this????
2018 Palomino Puma 255RKS, being pulled by 2020 Ford F250 w/PullRite Superslide 5th Wheel Hitch.
USAF--25 years and counting!
