Old 07-25-2016, 08:12 PM   #1
KayKay's Avatar
Electric front jack
So I pushed the button to raise my front jack and nothing happens. The light won't work and the jack won't lower or raise. I as able to use the hand crank but the nut has now split into 3 pieces. This Is My first electric jack so any help in narrowing downthe problem would be appreciated. It's a 2015 Wildwood X-lite.....used about 10 times total.
KayKay is offline   Reply With Quote
Old 07-25-2016, 08:15 PM   #2
Canadian Member
itat's Avatar
Are you sure you have 12V power to the jack? Is there a fuse in the line?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 07-25-2016, 08:33 PM   #3
KayKay's Avatar
Definitely had 12v. Not sure about fuse in line. Guess I'm a bit electrically challenged but do you mean literally a fuse in the wire running from trailer to jack? Sorry if I sound dumb...LOL
Old 07-25-2016, 08:54 PM   #4
Canadian Member
itat's Avatar
I don't know if yours will have a fuse "in line" or in the breaker panel. I added mine aftermarket and it has a inline fuse on the positive wire from the battery. From what you described it sounds like there's no power at the jack because not even the light will work.
Is the battery fully charged?
Fondly remembered:
Old 07-25-2016, 09:11 PM   #5
Scubanut's Avatar
Electric front jack
Sounds like the fuse at the Jack, look on the a-frame and you should see a fuse holder with a car fuse. It will likely have a plastic cover on it. I have blown two of these fuses, only while poring down rain.
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
electric
