Old 04-05-2015, 10:41 AM   #1
Electrical Outlet for Microwave/Convection Oven
The electrical outlet where the microwave convection oven plugs in is dead. This morning when I got up the clock on the microwave was not working. I discovered that the microwave was not working at all. I checked the breakers and found that the breaker for the microwave was not tripped but the breaker for the converter was tripped. I reset the breaker. I checked the electrical outlet and discovered there was no power to the microwave. All other outlets appear to be working just fine. Is there anything else I can check or do? Please help.
Bbbarker194 is offline   Reply With Quote
Old 04-05-2015, 10:51 AM   #2
Check and reset all your GFI outlets.
Old 04-05-2015, 11:04 AM   #3
GFI outlets tested and reset - no problem there. My RV is a 2014 Cedar Creek 32RL if that matters.
Old 04-05-2015, 11:08 AM   #4
Breakers all reset? If you don't have an inverter(youroo) unplug from shore power and start pulling outlets and remove the push in connections and use the screw connections only.
Old 04-05-2015, 11:11 AM   #5
Old Coot - breakers all reset. I don't know if I have an inverter or not - does the 2014 Cedar Creek come with an inverter? I have not added one. I am not sure what you are telling me to do with the outlets and screw connections.
Old 04-05-2015, 11:18 AM   #6
Lots of (Big Units) now have (Residential Refers) these have (Inverters),some Dealers/Salespeople don't even know this!? Youroo!!
Old 04-05-2015, 11:19 AM   #7
FR uses push in connections on the outlets where the wires are stripped and just pushed into the outlet. There are screw connections where you wrap the stripped end around the screw and tightened. IF you are not comfortable or knowledgeable with them, call a friend that is.
Old 04-05-2015, 11:20 AM   #8
I do not have a residential refrigerator. Are you telling me there is nothing else I can check or do to fix the problem? Do I need to get an electrician?
Old 04-05-2015, 11:21 AM   #9
So the safe way is to unplug the shore power AND disconnect the battery(ies) completely.
Old 04-05-2015, 11:28 AM   #10
The O/P now says that they don't have a Res.Refer. but LOTs of these Big Units Do.I will start another Post for Info! Youroo!!
electric, electrical
