Old 05-12-2016, 03:38 PM   #11
Flybob's Avatar
Originally Posted by rogerkathy View Post
Told to just turn off the EMS because the low amperage house outlets wouldn't harm the electronics in the trailer. .
I would be very careful taking any suggestions from the person who told you this as it it wrong. GFI's and EMS units sometimes don't play well together when connecting RV's to garage outlets
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-12-2016, 04:20 PM   #12
fonzie's Avatar
X2...
Fonzie
Old 05-12-2016, 04:41 PM   #13
I had same problem but gfci wouldn't reset after it tripped while DW was trying to use a blow dryer. 2 downstream outlets would'nt work. Turned out to be a bad gfci outlet. Replaced and all worked well after that. There was an outlet in the cargo bay that was hard to find that wasn't working and one one the island.
2013 Ford F250 6.7L lariat
2016 Wildcat 275 CKX
50 Gallon Titan tank
Firestone Ride Rite airbags
Airlift Wireless compressor
dbackerjim is offline   Reply With Quote
Old 05-14-2016, 04:37 PM   #14
Is there a way to check the GFI outlets besides the reset button?
rogerkathy is offline   Reply With Quote
Old 02-22-2017, 10:56 PM   #15
This may be an old thread, but the info. found here was very helpful to this newby! I check GFCIs in my house but hadn't thought of it for our trailer. Problem solved!
Kimmary is offline   Reply With Quote
electric, electrical
