Old 09-08-2012, 05:00 AM   #1
Eliminating the need for an Inverter for TV and DVD
we use a 200 watt inverter to run a small lcd tv and a portable dvd player(connected to the tv)
both tv and dvd have wall warts(ac adaptors) plugged into the 120 volt outlet when hook up is available and plugged into the inverter when dry camping
the TV requires 12volts dc from its adaptor, so i should be able to run it directly from the trailer 12 volt system easily, correct?
the dvd player requires 9 volts dc from its adaptor at 1 amp capacity, is there a way of getting that in my trailer without converting 12 dc to 120 ac then back to 9v dc
1998 Forest River 21rb
2003 Ford Windstar
2 bicycles and a 3 yr old husky
stevem is offline   Reply With Quote
Old 09-08-2012, 05:23 AM   #2
Does the manufacturer of the Dvd player make a car adapter? Otherwise one might be available from Radio Shack or other sources. The TV will run from a car adapter. Just use a multimeter to check polarity on the AC adapter and make sure it is the same when you hook up to 12 volt supply. Again, the manufacturer may sell a car adapter. My Jensen TV that came with the RV is 12 volt and came with a car adapter as its power plug.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 09-08-2012, 06:34 AM   #3
neither have car adaptors and probably arent available
the tv should be easy, just get some parts and make a cable
the dvd is a different story, it requires 9 volts @ 1 amp
2003 Ford Windstar
Old 09-08-2012, 06:38 AM   #4
MtnGuy's Avatar
Enercell 9-Volt 1000mA Vehicle DC Adapter : Adapters | RadioShack.com
Old 09-09-2012, 05:20 AM   #5
i'll check that out at radio shack or thte "source"
it seems redundant to run these items through an inverter, 12 vdc to 120 ac them back to 12 vdc!!
now the only items requiring an inverter are a sony camera battery charger, laptop charger and aa battery charger
2003 Ford Windstar
Old 09-09-2012, 05:30 AM   #6
ken0042's Avatar
I run my TV using a 12 volt adapter I bought at Canadian Tire. I had a look and I don't see it on their website any more; but it also had a step down function that let you pick voltages below 12 volts.
I just found a link on eBay; looks like this seller doesn't ship to Canada though. At least you have an idea of what to look for.
(Edit- looks like this is a 120 volt input. Mine looks almost the same; excpet it plugs into the cigarette plug of the trailer.)
GE 73606 Universal AC Adapter & Battery Eliminator with 6 Power Tips & 7 Voltage 030878736060 | eBay
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
