Old 05-09-2015, 05:50 PM   #1
Entertainment Center RV4000 no power
I have a 2014 BKIS that I just obtained. The entertainment CD/DVD/AM/FM center RV4000 does not power on. I saw in some posts that there is a reset button. I can't seem to find it. I also can't find how to get to the back of the unit as the manual says there is a fuse on the back of it. I suspect I have to remove the bevel and there are screws behind it, but I am afraid I will break it when I try to pry it off. There does not appear to be any other way to get to the rear as it is all enclosed with walls and cabinets. Any help will be appreciated.
portpd is offline   Reply With Quote
Old 05-09-2015, 06:00 PM   #2
Found this manual online for your unit. Looks like it based on your description. Page 17 shows the reset button and farther down the manual shows the bezel removed as well as the back for the fuse. Hope this helps if it is the correct model. Just be careful with the bezel, it will be OK.
RV4000 Linear Series Wall Mount Radio | In-Wall Car RV Stereo
http://www.magnadyne.com/catalog/dow...uctFileID=2144
2002 GMC Sierra 2500HD Duramax
2008 Rockwood Sig Ultra Lite 8315SS
Livin the Life is offline   Reply With Quote
power
