Old 09-20-2015, 10:59 AM   #1
Eureka Yellow Jacket vacuum
Hi folks - Wondering if anyone has ideas or solutions for the following. We have central vacuum system on a Palamino Sabre 34TBOK-6. It is a Eureka yellow jacket. I changed out the bag for the 1st time and now it doesn't work. I dont think there is a mechanism that overides not to run if the cover is not put back on correctly.
Any ideas? Has anyone had this issue?
Thanks in advance for your input.
Nastyfoot is offline   Reply With Quote
Old 09-21-2015, 05:22 AM   #2
Fulltime family RVer
Can you define, "it does not work"? Like it doesn't come on? It doesn't suck?
The way that it is installed is:
- There is a 120v power from the vacuum to a plug.
- There are 12v lines running from the vacuum to the wall outlet.
If either of these are disturbed, it's not going to turn on.
ependydad is online now   Reply With Quote
Old 09-25-2015, 06:12 PM   #3
wingedone's Avatar
Actually, yes it does need to be put on correctly. We have the same. Was checking something out years ago and found out it would not run unless the cover is in place. It's all plastic. How it knew, I have no idea.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
