Old 11-05-2010, 08:09 AM   #21
Hello. I got a used RV two years ago that fits this description. Could you tell me about the fridge though. When they say "two door", is that like a two-door side-by-side fridge at home, or are they talking about the freezer door and the fridge door being two doors. I'm guessing it's not mine with just one freezer and one fridge door right?
My fridge is not cooling well, so I thought this might be the reason. But I'm thinking not.
jnhgustin is offline   Reply With Quote
Old 11-05-2010, 08:18 AM   #22
Herk7769's Avatar
Originally Posted by stefatc View Post
realebill for my part, I haven't found any problem yet! I have to figure out how I turn it to 120vts!
It is a tiny rocker switch in the lower left corner under the outside cover of the water heater. Hard to reach in my installation and I am told some have a safety cotter pin through the switch.
MAKE SURE there is water in the tank at all times.
Running the 120 volt heater element dry WILL burn it out in seconds.
HAM CALLSIGN - KC3FFW
Old 11-05-2010, 08:48 AM   #23
MtnGuy's Avatar
I think the reference to 2 door is an over/under arrangement with 2 seperate doors.
Just get the model number from the inside of your fridge, and run it thought the numbers on the recall list.
Old 11-05-2010, 08:54 AM   #24
Thanks. I'll do that. It's stored about an hour away, so I was hoping to avoid it til I go again.
Can you tell me too, is there some way to set the "coldness" of the fridge, like I do on a regular fridge?
Old 11-05-2010, 11:06 AM   #25
Inside the refridgerator portion at the top you will see a metal unit with vertical fins (maybe 4 inches high) on a fin at one end (probably the right hand side) you will find a smallish sliding attachment. To adjust the temperature, slide this attachment up or down slightly. Don't remember right at this time which direction "up or down" is cooler, but experimentation will tell you that, if someone else doesn't chime in.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 11-05-2010, 11:53 AM   #26
MtnGuy's Avatar
...VTX-AL
Shucks, I can't ever remember either....thanks goodness for a little sticker there instructing me which way.
Old 11-10-2010, 08:34 AM   #27
Dometic Recall...Is it fixed?
We recently bought a used Rockwood and the fridge is included in the recall. Without going into great detail and boring you, I'll just say that I have no way of knowing if the previous owner had it fixed.
Is there an obvious way by looking to know if the upgrade has been done? I'm in there anyway to replace the 120v heating element. Thought maybe some of you folks who've had it done could help.
Thanks, Joe
smilin joe is offline   Reply With Quote
Old 11-10-2010, 02:49 PM   #28
RV Newbie
buzzards27's Avatar
Thanks, Joe
Joe, thanks for your post. If it wasn't for you, I might have missed the info about the recall. This unit has had two prior owners and it slipped through the cracks. Called the local RV center this morning and it wasn't worked on. Before the call I did look inside the outside refer cover and it didn't appear that any mickey mouse alteration were made. maybe someone can post what a post repair system looks like.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 11-12-2010, 02:46 PM   #29
Thanks, Joe
Just thought I'd try again, by now this is probably not a very hot topic. I assume most people have already had the upgrade done. Maybe mine is too, just don't know what to look for.
Old 11-12-2010, 07:29 PM   #30
carl.net
Just call Dometic per the recall notice.
"OWNERS MAY CONTACT DOMETIC AT 888-446-5157."
They can tell you over the phone if the work has been done and tell you exactly who in your area has the parts on hand so you can get it repaired asap. I have a guy coming out Monday to fix mine.
carl.net is offline   Reply With Quote
