Old 06-15-2014, 06:20 AM   #51
Herk7769's Avatar
Originally Posted by HarrynSally View Post
I'm trying to get mine done, I would like to know what they do and what they add to it myself.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
The repair was quite easy and took about 30 minutes.
HAM CALLSIGN - KC3FFW
Old 06-15-2014, 01:12 PM   #52
HarrynSally's Avatar
How you did the repair yourself?
HarrynSally is offline   Reply With Quote
Old 06-15-2014, 03:00 PM   #53
Herk7769's Avatar
So, a long story as short as I can:
1) Looked up my serial number on the web page and it said I needed the recall done on my camper.
2) I DID NOT want to haul my camper to my "so called" dealer for reasons anyone who follows my posts would be happy to expand upon.
3) I looked up Authorized repair centers on the Dometic web page and was shocked to find one across the street (about a block away).
4) While you can't order the recall pack yourself, the "Authorized Dometic Repair Center" turned out to be a garage. When I went there to have them do the recall, the owner realized his own camper had not had the recall done and ordered two sets (one for him and one for me).
5) So the kits came in and it was so simple to do, the owner showed me the install instructions and asked if I wanted to try it. I said sure (of course) as the kit was free. I watched him do his (about 30 minutes from opening the box through applying the sticker) and went home.
6) Got home and found out mine was already done at the factory (The FULL model number was not RM but DM and had not realized there was a difference when I was on the web site).
7) Turns out my buddy Val needed the recall done to his Montana, so I used my kit to do the recall on his fridge. (OK it took me about 15 minutes more than the mechanic as I needed to hunt all over the garage for tools my dog hid.)
That's my story.
Old 06-16-2014, 11:59 AM   #54
Ok, Could you tell me as far as parts, What does the recall consist of?
Old 06-16-2014, 01:12 PM   #55
jimh's Avatar
Consist of a metal shield that protects frig, air intake grill, and the wood from direct flame. A temperature breaker mounted to the boiler insulation shield abt 4 or so inches above the burner.
Ideally, if the boiler leaks and ignites, the gas burner will shut down and the will hopefully go out.
If the boiler developed a leak, The gas burner can ignite it and flare up.
jimh is offline   Reply With Quote
Old 06-17-2014, 04:57 PM   #56
Thank you very much for the info.
Old 06-17-2014, 05:03 PM   #57
Originally Posted by Herk7769 View Post
...OK it took me about 15 minutes more than the mechanic as I needed to hunt all over the garage for tools my dog hid...
I have the same problem with our dog. She won't put the tools up and just scatters them all over.
Old 06-17-2014, 06:55 PM   #58
I couldn't get the previously posted link to the recall working but was able to find the recall page here
Dometic Recall Information - Dometic
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
azjerry is offline   Reply With Quote
Old 06-17-2014, 07:04 PM   #59
BamaBob's Avatar
Well at least she doesn't pee on them like out cat does
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-17-2014, 07:18 PM   #60
Plain Old Member
Just to make sure I read everything right, here's my info. The fact that my model number is DM2862, should mean the recall has already been done, or my unit is not affected, correct? I know it's new, but wanted to make sure. Recall doesn't even let you select our model as a possibility, just the RM2862.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
