Old 08-14-2014, 07:43 PM   #1
Explain pre-wired for second A/C
Spent a little time searching trying to inform myself but didn't really figure it all out.
My trailer is pre-wired for a second a/c in the front bedroom. There is a breaker for second a/c and the block off plate in the roof by the bedroom roof vent.
Question is this, would a second A/C be installed into the ducted system running off the therm o stat with the other unit. Both run together to increase air flow in the ducts.
Or would it be like an older trailer A/C where you operate the controls from the a/c unit on the roof itself?
Thanks!!
First trailer with this option so learning.
2017 GMC Sierra Denali HD
2014 XLR Hyper Lite 30HFS5
Toys-
Yamaha G9 Golf Cart
2010 Harley FLHX with lots of mods
bowtie_guy is offline   Reply With Quote
Old 08-14-2014, 08:02 PM   #2
It would work like the old units. Air coming out of the a/c unit only with controls on the unit unless you wanted to wire in a thermostat
gschick is offline   Reply With Quote
Old 08-14-2014, 08:09 PM   #3
TURBS's Avatar
Normally there's a second thermostat mounted in the same room as the second a/c.
Normally you'll get a ducted a/c and they both work together that way.
TURBS
"SABRE OWNERS UNITED"
Old 08-14-2014, 08:34 PM   #4
Phat Phrog Stunt Crew
elind's Avatar
Just had a second a/c installed on my 5er. When my was pre-wired it had
it's own breaker and a thermostat in the bedroom. The a/c is direct vent into the bedroom that sits on the 14x14 roof vent. It doesn't connect to the air ducts. The RV will have a 50 amp service to power the two a/c's.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-15-2014, 03:05 PM   #5
My second AC in the bedroom was pre-wired for the unit only and it is a13,500 BTU stand alone unit, not ducked or connected to the duck work for the 15,00 BTU unit in the living/kitchen area which is ducted.
whj77372 is offline   Reply With Quote
Old 08-15-2014, 03:34 PM   #6
Witch Doctor's Avatar
All these answers are correct depending on unit model. Your sales person might know if it is joint ducted or just a bottom drop. Joint ducting would be preferred in IMO.
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-15-2014, 04:55 PM   #7
jtstromsburg's Avatar
Like turbs said, on my sabre, I added a second 15k btu ac unit and it is ducted. There was a wall mounted stat from the factory, along with 120v power near the original vent
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
