Old 11-06-2014, 03:33 PM   #21
Mrs Evans's Avatar
Originally Posted by f1100turbo View Post
But they did recall fridges for a potential leak.
Here.
https://www.google.com/url?sa=t&sour...xRt_AkrhBnHOvg
Turbs
Yay! This one does not affect me
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 11-06-2014, 03:39 PM   #22
onetonford's Avatar
I think it is a heat shield and a thermo click type switch which is what is on mine. The red wires go to the switch and the shield are in front of the valve
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 11-06-2014, 03:42 PM   #23
Mrs Evans's Avatar
Thank you Onetonford! I appreciate the pic
Michelle Evans
Katy, TX
Old 11-06-2014, 11:19 PM   #24
Infractee
This recall wasn't due to "exploding"
Refrigerators.
It had to do with a shield.
Turbs
Well, kinda I guess.. the shield keeps the explosion from happening. If the ammonia leaks the shield diverts it away from the direct flame burning, which prevents the explosion.
RhoZeta is offline   Reply With Quote
Old 11-06-2014, 11:28 PM   #25
Infractee
Originally Posted by Still Kickin View Post
Please forgive me for asking to see the backup references on "Dometic refrigerators" as well. Seems to me it was a reasonable request for the related article(s), so all Forest River owners who have one of those in their RV, can be better informed.
After all kind sir, that is one of the major benifits of this forum, wouldn't you agree!
Did you really need to be nasty.
Point is, this has been an ongoing issue for several years, the OP posted about Norcold having issues, several replys were along the lines of "no worries here, I have a Dometic" so I posted what seems like basic, old knowledge that Dometic has also had problems, this is not just a Norcold thing.
Old 11-07-2014, 06:39 AM   #26
mud yapster's Avatar
Thanks for the info. on this I'll check my new unit but it is a 4 door side by side type frig. but I'll be checking it for recalls. Thanks
P.S. keep your smoke detector working
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-07-2014, 07:03 AM   #27
Herk7769's Avatar
"Yet the company hasn’t changed the design that a Thetford employee acknowledged in testimony lies at the heart of the problem, a metal boiler tube that can crack, allowing flammable gases to escape."
I think he was referring to this part of the article.
"A company engineer also testified in a 2012 deposition that Norcold has paid claims on more than 800 fires allegedly caused by its 1200 series refrigerator since 1999."
The lawsuit seems limited to one series of NORCOLD RV fridge; the 1200 series.
"(Sweden’s Dometic Group makes refrigerators with a similar design, which have also been the subject of lawsuits and an NHTSA recall.)"
This recall added a thermal switch to shut down the fridge in case there is a stack overheat for any reason. The recall was limited to certain fridge models that used a boiler tube shield made similarly.
Official Dometic Recall - DometicUSA
Anyone who has not done this simple modification is encouraged to have it done. The recall has been around for several years and involves adding a heat sensing thermal breaker and a sheet metal shield (that also prevents flame blowout while traveling).
The article referenced indicates over 80% compliance to date, but that number is based on total units manufactured and does not include scrapped units or units that were repaired/replaced prior to the recall.
If your fridge has the stack over temperature breaker your unit is as safe as any evaporative unit is going to be.
Name:	Camper Fridge 007.jpg
ID:	65971   Click image for larger version
Name:	Camper Fridge 004.jpg
ID:	65972   Click image for larger version
Name:	Camper Fridge 001.jpg
HAM CALLSIGN - KC3FFW
refrigerator
