07-05-2016, 09:16 AM
Extension cord
It it ok to run about 100 foot of cord to plug in to a 110 outlet so I can run fridge?
2015 Cherokee 284bf limited
07-05-2016, 09:29 AM
Yes.
2011 Traverse LT, 3.6L, FWD
07-05-2016, 10:44 AM
You don't say what wire guage of cord you are using, but just the fridge (and the converter, which doesn't use much if its just maintaining the battery) connected should be OK.
Power loss is proportional to the square of the current. RV absorption fridge boiler elements draw about 3 amps so the power loss, and thus the voltage drop, will not be too great. Just don't use anything else.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
07-05-2016, 11:22 AM
Dave, where is the power lost? Is it related to the length and gauge of the cord? Trying to understand the above but I guess I need a little more detail.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
07-05-2016, 11:38 AM
It your everyday orange cord, just trying to cool fridge down before we leave. I have to run propane on shore power for fridge?
07-05-2016, 12:23 PM
Should be OK. I leave mine plugged in while in storage with the same cord (just to keep the batteries charged)
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
07-05-2016, 05:05 PM
The power is lost in resistance heating of the cord wiring. That's why the cord gets hot. Shorter cords and heavier wiring reduces the heating losses.
This is really all the fridge heater element is, but it's a wire that is designed to get hotter, just like the heater wire in a space heater.
This also results in lower voltages at the end of the cord. So don't add any more load unless you get a shorter cord with heavier wire.
07-05-2016, 05:12 PM
I've done this for 12 years without any issues.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-05-2016, 05:18 PM
Sky&Scuba
I would never own an extension cord at 100 feet less than 12 gauge. Better to go with 10 but the cost and weight start going up fast.
Yes Voltage Drop is the issue and the lower the voltage the more amps and more heat is created.
Just running the Fridge probably is not going to cause an issue.
Voltage Drop Calculator
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
07-05-2016, 06:13 PM
Yes, I understand that. But saying "Power loss is proportional to the square of the current" sounds like a formula, and any such formula would have to take into account the length and gauge of the extension cord, would it not?
07-05-2016, 06:22 PM
Sky&Scuba
Yes you are correct see my voltage drop calc that I posted above.
07-05-2016, 06:54 PM
Yes. But you don't need to do the calculation to know what you need to do.
Power is equal to current squared times the resistance. The wire in the cord develops a certain resistance per foot. This resistance is related to the material of the wire and the diameter of the wire. Since most cords are made of copper, the resistance is then proportional to the size of the wire. Smaller wire, more resistance per foot. Longer cord, more feet, hence more resistance in the cord.
Current is proportional to the load you put on the end of the cord. If you operate something that consumes more watts (A/C, water heater, toaster, fridge), then the current it draws goes up.
So ideally, you want large wires, shorts cords and low wattage. If you change one in the "wrong" direction, you need to change one or both of the others in the "right" direction.
Consider your 30 amp RV cord as "adequate" for running most things. But if you start adding extra, smaller gauge extension cords to it, you need to start dropping the wattage of whatever your running.
Now, all that being said, in my driveway I've run my A/C with a 100 foot "normal" (not sure of it's gauge - probably 14awg) extension cord and have had no problems. BUT, I haven't run anything else, either.
07-05-2016, 09:25 PM
So I'm good to run just the fridge?
07-05-2016, 10:35 PM
Sky&Scuba
Most likely yes for just the fridge.
Get you one of these and plug it into an outlet in the RV this will tell you for sure. I have the digital one. Also won't hurt anything after you have this turn the AC on for a few min with your 100 foot extension and you will see what happens to the voltage drop. Again won't hurt nothing unless you left it on running for hours. Most likely an 100 foot 14 AWG extension cord connected to an RV and running the AC will melt the extension cord in a few hours.
https://www.amazon.com/Prime-Product...dp/B000BRFTH6/
https://www.amazon.com/Prime-Product...dp/B002P48KLK/
We just traded campers and when I get a new one I pretty much tear it part adding upgrades I want. I also find alot of issues from the factory and fix them as I go.
Here is the thread I started on the new camper.
http://www.forestriverforums.com/for...ks-111535.html
07-05-2016, 10:57 PM
Mine never got hot. Maybe it's 12 ga, but doubtful.
07-05-2016, 11:16 PM
I fried my fridge mother board. I was temporary using the trailer for a week at my home while we were moving. I only was using a few lights and tv, and fridge. I was to far away from my 30 amp RV home connection. So I plugged into 15 amp using the trl heavy gauge 30 plug, I used and adapter and I think 14 ga wire extension cord that was about 100 feet. Needless to say my adapter melted and now my fridge is fried. Two lessons for me, don't use 14 gauge wire with adapter for long periods, and I have a progressive EMS and I didn't use it because I though at home there was no need.
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
07-06-2016, 09:57 PM
I will be plugging it in tomorrow so we will see how it goes!!!
07-07-2016, 07:38 AM
2015 silverback 31IK
2023 f350
07-07-2016, 07:41 AM
The trick is to ensure the battery is charged already or disconnect the battery. The charger will also heat up when trying to charge with it's input amperage low. Be sure not to try the ac or water heater.
07-07-2016, 07:55 AM
Geez, I missed that completely. Thank you.
Thanks for the explanation. Between the information I've received and the voltage drop calculator link I have a better understanding.
