It's possible that the fan itself has died. I suspect that's what happened to ours this year as well. I tested by unhooking the wires from the sensor on the top fins and touching them together. The fan didn't start. This fan is the same as typical 120mm computer fans, so I ordered some cheap ones from Amazon, a 3-pack for something like $20. As the mounting bracket could take two (only one was installed), I put two in which was fairly simple as the fans I purchased could be easily daisy-chained. I just had to cut one plug and splice into the original power and ground cable. I tested the same was as above and they ran so I figure it's good now, though it hasn't been hot enough here to make them kick in.
I should add that my fridge still worked normally, but as I mentioned it hasn't been super-hot here in southern Saskatchewan yet. I only tested as this is a new-to-us trailer and I don't think our previous trailers had a fan.
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
