Old 03-25-2013, 07:35 AM   #1
Exterior tv mount
How many of y'all have done this? Was it easy to do? What did you use to drill into the Fiberglas? Sorry so many questions. Been thinking about this for a while now. Thanks.
Justin
Horns07 is offline   Reply With Quote
Old 03-25-2013, 07:38 AM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Curious myself...subd
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-25-2013, 08:54 AM   #3
Fulltime family RVer
I haven't done it- but I've seen posts where people used the track that normally holds the small grills to the side of the camper and fabricated a mount that attached to it. Made it easy to put on and take off.
Others have put full motion mounts into the storage bay or outside kitchen that extend out past the side of the camper.
Old 03-25-2013, 09:23 AM   #4
Justin
As far as drilling into the fiberglas, I just use regular metal cutting drill bits. I fabricated a bracket to use the BBQ rail and it works great for us. With the way I made the mount, it will also sit in the basement unattached to anything. Since I made a good cover for it, it will stay on the outside except when transporting.
Old 03-25-2013, 09:43 AM   #5
Do you have any pictures of this? And also how did you locate the studs?
2012 dodge ram 3500 dually
2008 sandpiper 305RGS.
Old 03-25-2013, 09:58 AM   #6
Didn't need to find the studs, but a stud finder works.
ID:	26345   Click image for larger version
ID:	26346   Click image for larger version
ID:	26348   Click image for larger version
ID:	26349   Click image for larger version
Old 03-27-2013, 04:35 AM   #7
Would like to find a mount I could use a 22" tv in the bedroom as well as outside . this looks like it would work well on grill rail . I need something qwick change but have had no luck finding !
valerie&robert
Valerie56 is offline   Reply With Quote
Old 03-27-2013, 07:34 AM   #8
Senior Moment
rockport's Avatar
Check out Thule smart rv mount. Might be just what your looking for.
rockport is offline   Reply With Quote
Old 03-27-2013, 08:35 AM   #9
Might buy 2 mounts and instead of using the bolts & nuts to attach them, just use the bolt without the nut to make change over a little faster from outside mount to inside mount.
