05-30-2014, 12:01 PM
External coax jack
With the antenna turned on. can I hook up a TV to my external cable jack and get the antenna signal through it? The jack is designed to hook up to outside cable as my TT has no outside TV hookups. Just a thought as I wanted to watch TV outside Sat. night but didnt want to run a cable through a window.
Anyone tried this?
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
05-30-2014, 12:09 PM
Good question. Damn good question. I'd say try it and report back.
05-30-2014, 12:37 PM
Yes, you should be able to.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
05-30-2014, 12:42 PM
Let me know if that works too.
05-30-2014, 12:50 PM
Looking at the schematic for the Winegard, the cable in jack is disconnected when you turn the amp on. The switch is double throw, double pole, with one side used to apply power to the amp and the other used to switch inputs.
You might get a little "leakage" signal to the cable jack, but not enough, I'd imagine, for a decent signal.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
05-30-2014, 01:37 PM
I'll give it a try tomm. and let ya know.
05-30-2014, 02:53 PM
Where can I find that schematic? Thanks in advance!
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
05-31-2014, 12:33 PM
The different models are all over the net. This one is typical.
You can see where the cable connection switches off when antenna is selected.
05-31-2014, 12:43 PM
This is what the back looks like.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-31-2014, 12:46 PM
Ret E-9 Anchor-clanker
Great picture of the antenna switch, Thanks Herk...
05-31-2014, 12:51 PM
If you look at the circuit board in the one Herk shows, you can see where the coaxes switch.
06-01-2014, 05:36 PM
Converter
