Old 02-11-2016, 12:35 PM   #11
Witch Doctor's Avatar
Originally Posted by duramaxlbz View Post
Ok, guys I been doing some searching on the forum and found some OK info, I see lots of people are using a startech 80x25 ball bearing fans. The factory ones just make to much dam noise. So my question is can I just unplug the fans for my first trip till I get the new ones? Also what connector should I get the tx3 or the lp4?
the Refer you have do you have it in a slide out or roof vented?...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-11-2016, 12:36 PM   #12
Canadian Member
itat's Avatar
Originally Posted by DSQR View Post
FYI - If noise is the only issue, a ball bearing fan will produce more noise than a sleeve bearing fan.
I had never thought about bearing types in computer case fans but this suggests that sleeve bearing fans get louder as they get older and its the opposite with ball bearing fans - they get quieter with more use. Plus the ball bearing fans generally last longer and sleeve bearings are more suited to a vertical installation rather than horizontal.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 02-11-2016, 02:08 PM   #13
duramaxlbz's Avatar
It's in the side out.
duramaxlbz is offline   Reply With Quote
Old 02-11-2016, 04:36 PM   #14
Your going to need the fan but order 2 fans and splice the red lead together,,
Old 02-11-2016, 04:39 PM   #15
duramaxlbz's Avatar
That's the plan. I am going to replace the Two factory fans with two duel ball bearing fan.
fan, fridge, upgrade
