Old 10-24-2016, 11:11 AM   #1
Fireplace wont keep me warm and cozy
I have a 2015 Flagstaff 27rls with a 23" chinese fireplace in it. I never really used it till this weekend. Seems to work fine on low 750w but when the DW gets cold and turns it up to High 1500w it runs for 1 minute and shuts off. I suspect it is due to a high temp limiter. have to turn it off for 5 minutes to get it back going again as long as we keep it on low. Anyone else have an issue with theirs and is there any fix or something to look at to fix
2016 Cedar Creek 34RL
2014 Ram 2500 4x4
LindaNTom is offline   Reply With Quote
Old 10-24-2016, 11:16 AM   #2
Air flow? High limit switches can fail, but do you have a high air flow to along with the 1500 watt setting?
donniedu is offline   Reply With Quote
Old 10-24-2016, 11:31 AM   #3
the fan stays at the same speed when I switch from low to high heat . Not sure if there is an issue and the fan is suppose to go to high or not . the pamphlet that came with the trailer does not say it has 2 speeds, but then again it doesn't say the manufacturer name either.
2014 Ram 2500 4x4
Old 10-24-2016, 11:33 AM   #4
Forget the dealer, time to call FR directly and ask them. They have always been happy to answer my questions.
Old 10-24-2016, 11:43 AM   #5
Thanks for the help
2014 Ram 2500 4x4
Old 10-24-2016, 12:02 PM   #6
RSchleder's Avatar
My fireplace needs to run for 20-30 minutes on low prior to clicking it to high. If I follow this procedure it will run just fine on HIGH for as long as I wish. Not sure why it operates like this, I just figured it is what it is!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 10-24-2016, 12:13 PM   #7
BamaBob's Avatar
X2 It has been chilly this weekend and we have just heated the coach with the floors.
It was particularly cosd this morning so I turned on the fireplace, closed the door to the front and when I opened it up 10 min later it was probably 75° in the front of the coach!
Those electric fireplaces work great (when they work, in your case ) When we had our 5th wheel, we could leave the fireplace on and keep the whole unit comfortable warm on nights that it got into the 30s
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-24-2016, 04:29 PM   #8
Fireplaces?Walk'n to school (up hill both way's) in the snow. We never had any of this fancy Dan stuff. When we camped sleep'n in a tent when it was minus---- Oh sorry flashback to what Gramp's would tell us.
mike.t is offline   Reply With Quote
Old 10-24-2016, 04:35 PM   #9
TimVWulp's Avatar
Hi when you turn the fireplace on hi are you also setting the timer for how long you want it to operate? If you don't when the room set point temperature is reached the fire place will turn off when it reaches the set point temp. This is one of them government mandates thy made for electric blankets, heating pads, heater and so on to help you save electricity. My fire place will turn off when it reaches temp set point if I don't set the timer.
Hope This Helps Tim
TimVWulp is offline   Reply With Quote
Old 10-24-2016, 05:06 PM   #10
this may sound like a stupid answer, but are at a 50 amp hook up? we can't use ours unless we have the 50 amps.
ValMelton is offline   Reply With Quote
Old 10-24-2016, 05:41 PM   #11
We had a similar problem and it was replaced under warranty. Now it works great!
nicholsm4 is offline   Reply With Quote
Old 10-25-2016, 04:33 AM   #12
Is there a temp control? Maybe set it higher to keep it running
Big Bill is offline   Reply With Quote
Old 10-25-2016, 05:40 AM   #13
On mine you can't do a lot from the unit and must use the remote control. Set temp higher...and it seems to work nicely. Not a roaring fire, but takes the chill out quickly.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-25-2016, 05:45 AM   #14
B and B's Avatar
Our fireplace says it is 72 and never shuts off. We do turn it off when sleeping as the bedroom gets way too hot as heat rises. Rely on furnace and cheap propane overnight.
B and B
Old 10-25-2016, 12:57 PM   #15
Thanks for all the suggestions.
RShleden I tried your idea and that didn't seam to help on mine. Thanks anyway
Tim: I'll give yours a try tomorrow. will let you know
Val; Mine is a 30 amp trailer. it doesn't throw the breaker so I assume it has enough power.
2014 Ram 2500 4x4
Old 10-26-2016, 05:02 PM   #16
Crusader2014
Happy Camper
If we open the 'screen' that hides the knobs, the heater cycles to maintain the temp we select. If we close the 'screen' the heater cycles constantly and doesn't warm the space. I don't know why the screen should interfer, it must push back the heat to the sensor somehow. But the fireplace heater works great with the 'screen' open.
kshinnick is offline   Reply With Quote
