Old 06-16-2015, 12:17 PM   #1
Flashing refridare
Had my Rockwood on the driveway that has a incline and the refridare started flashing and the light on the inside also turn off after I open it. Put the rv on a flat ground it still flashing will
Not cool also if I keep in on the driveway when it is off can it still hurt the refridare after I get it repair
Rkluge777 is offline   Reply With Quote
Old 06-16-2015, 12:28 PM   #2
I guess you're talking about the refrigerator ?
They need to be pretty level to operate at their best.
If not working...I don't think in makes any difference.
Were you on gas or electric ?
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 06-16-2015, 12:56 PM   #3
VinceU's Avatar
Ammonia reefer will be damaged if operated over time out of level so as to restrict fluid flows in the condenser coils. Burner will over heat the fluid. Domestic simplifies level as comfortable to stand next to the box. My guess your problem is the electronic control board is defective. No further damage will occur unit off.
Old 06-16-2015, 03:09 PM   #4
Refrigerator
Even when you just using a power cord and its un level no gas will it still cause a problem.
Old 06-16-2015, 05:17 PM   #5
Pull the outside fridge grill off and follow 2 wires that go to the fridge chimney on the right. There is a reset button located between where the two wires attach to the switch on the chimney. It can be hidden in insulation. I was told that this switch cuts off the fridge to prevent damage when the trailer is not leveled properly. Hope I'm not sending you on a wild goose chase on this.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 06-16-2015, 05:26 PM   #6
Bob
The reset you are referencing is a hi limit stack temperature reset. Has nothing to do with whether the refrigerator is level or not.
