Closed Thread
Old 05-04-2010, 04:54 PM   #91
Hatchet58's Avatar
Easy way to Turn Power Off on concertone, find Fuse, Pull fuse and at the same time turn Braker OFF, turn back after 5 mins it is like a Computer, It will reset itself,
Hatchet
Chevy 2500HD Diesel
07 SandPiper F305
Days camped 2011 "3" so far,
Hatchet58 is offline
Old 06-12-2010, 06:17 AM   #92
I also have the ZX600. I have two issues but one really only bothers for me now. #1 have the hissing coming through Zone A which is annoying cuz my kids watch DVDs there. The second is the radio reception sucks! I can live with that for now as I have XM radio hooked up. So back to #1 my options are checking the ground or an inline filter by the convertor may fix this? I have a Signature Lite 8313ss, does anyone have a write up to try these fixes? Also if that would not work, would it be possible to reconnect the wires behind the unit. I mean switch A and C connections? Or would I lose a lot of power and the woofer doing this? I just want to get by without bying a Jensen already. Thank-you,
Chris
Chris357 is offline
Old 06-12-2010, 08:13 AM   #93
firedude01's Avatar
Dodge Guy do you have any pics ? what model JVC did you use?
firedude01 is offline
Old 06-13-2010, 09:28 AM   #94
Herk7769's Avatar
Lol
"Find Fuse"
Ah, now there is a project! In my unit it is behind the control head which has to be removed for access.
Lou and Laura - Shopping for a Camping Buddy
2008 GMC Sierra 30000HD Crewcab SB Allison Duramax
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 06-14-2010, 11:18 AM   #95
robert2101a's Avatar
Hi
My apologies in advance if this is in the wrong section or thread.
I have a new Flagstaff 831RKSS with factory installed ZX700, a Konka TV and a Toshiba TV. There is an aerial as well. All the wiring is hidden so I cannot tell how all is hooked up to each other and correspondingly, I have trouble getting items to work. The bedroom TV appears to be hooked up only with a coax cable. The radio works and I can play a DVD to the living room TV only. I cannot get the DVD to play in the bedroom. Similarly, I cannot seem to get any TV stations on either TV. Are they to be tuned through the ZX700 or through the TVs? Any help on this matter is greatly appreciated. Further specs can be provided if needed.
robert2101a is offline
Old 06-14-2010, 11:25 AM   #96
I don't think the concertone will have anything to do with your tv stations. All of this is done through the tv and only the tv sound is played through the concertone if I am correct about how it works. As far as the dvd playing in the bedroom, you will probably have to run wires all the way from the tv to the concertone to get the dvd to play in the bedroom. Its probably only hooked up to the tv in the living area.
blake2727 is offline
Old 06-14-2010, 11:39 AM   #97
Herk7769's Avatar
Cool This question is tougher than it looks
I have an almost identical setup and after a YEAR I am still trying to figure it all out.
1) "The radio works and I can play a DVD to the living room TV only."
Yep you got it. The Concertone DVD player outputs through the COMPOSITE input to your TV NOT to the RF coax.
2) "I cannot get the DVD to play in the bedroom."
Yep, see above. The only way to do this is to run a RCA splitter off the COMPOSITE output from the Concertone and run one leg to the LR TV and the other to the Bedroom.
3) To set up either TV the AMP MUST be turned on. Press the little black button on the wallplate and make sure the little green light is on.
http://www.winegard.com/kbase/upload/2451489.pdf
is the manual for the amplifier.
The output from the AMP goes to a splitter. One leg goes to the LR TV RF input and the other leg goes to the BR TV.
You must do a manual search setup on each TV once the antenna is pointed at the stations broadcast antenna.
Antenna Index
For more info on antennas than you can stand.
I have NOT figured out how to get CABLE reception to the BR yet.
(LR TV is fine) still trying to figure out why I can get Antenna feed back there but not cable. Maybe my amp is bad.
Still trying to get ANYTHING from FR on the subject.
Lou
Herk7769 is offline
Old 06-17-2010, 08:46 AM   #98
gillguy's Avatar
Jensen AWM970 AM/FM/CD/DVD/USB/iPod Ready Wall Mount Stereo for RV/Marine/Travel Trailer/Toy Hauler/Cargo use - Stereo System
on sale for $245.00
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
gillguy is offline
Old 06-17-2010, 02:07 PM   #99
Does the jensen AWM970 have surround sound?
copyitfast is offline
Old 06-17-2010, 02:24 PM   #100
Herk7769's Avatar
Update on BR Cable
I had a bad connector behind the bedroom wall plate.
It was intermittent and Digital was hit or miss.
Cut off the old connector and reaplaced it.
Everything works now.
From what I read the Jensen is stereo only.
You would have to add a surround sound decoder to utilize the 5.1 speaker system in the newer campers.
Herk7769 is offline
Closed Thread
