Closed Thread
Old 07-18-2010, 08:22 PM   #121
Originally Posted by Fre tech View Post
Jrebhun
The hum your picking up is frome the converter you will need an inline condenser that will fix the hum for you
you can pick on up from radio shack it the same condenser you would put on the car radio
hope you find this helpfull
Fre Tech
Does anyone have a write up or pictures on where to install the filter on the converter? I have a 2008 Signature Ultra Lite that I would like to try this fix on. Thanks!
Chris357 is offline
Old 07-22-2010, 11:56 AM   #122
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
The RadioShack noise suppressor should give you "some" instructions, but I believe it might be close to the unit (as in probably directly behind it).
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline
Old 08-11-2010, 09:17 PM   #123
Question Concertone Zx500
No tech knowledge and one day the ZX500 works then the next only the CD player works, no radio very frustrating and trying to fine repair person is almost impossible when it is in your rig and they have no place to park to work on it. Live in Canada and Concertone will not mail new set to us in Canada. Looked for shorts, loose wires, antenna etc.see no problems.
pandjfarquhar is offline
Old 08-15-2010, 07:11 PM   #124
firedude01's Avatar
we are on our second unit now this one is a year old and its acting up the radio quits then plays off and on , the dvd player doesnt work? im about fed up with it and the dealer wont really help i hvae to call FR to see what they say
firedude01 is offline
Old 08-16-2010, 10:06 AM   #125
Concertone Zx500
Finally found someone on Vancouver Island to look at our Concertone ZX500 and he will try to get parts. Can not order from Concertone as we live in Canada and they will not mail to us. I'll let you know how we make out with repairs.
Old 08-18-2010, 07:50 AM   #126
Owner - RVtronics
Bob Fields's Avatar
You should pull out the unit and check the wiring yourself - its easy and the wiring diagram in on a label on the back of the unit so its right there. A loose or bad connection could be the issue...
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Old 08-18-2010, 08:15 AM   #127
Firedude,
I concure with Bob about checking the wiring, especially if the radio issue happens at the same time as the DVD player issue. With mine it was just the CD/DVD player. Radio worked 100% of the time. When the dealer worked on it he said it was wiring loose. It started again shortly after the dealer trip so I pulled it out and used crimp connections. It didn't help. Swapping the unit out for a Jensen did though. I will never own a Concertone unit again.
Frank and Jean
Retired Navy
DAV Life Member
'09 Rockwood Roo 233s
'03 1500 Silverado LS
I didn't say it was your fault, I said I was going to blame you.
It may be that your sole purpose in life is simply to serve as a warning to others.
The things that come to those that wait will be the scraggly crappy junk left by those that got there first.
popeye59 is offline
Old 08-19-2010, 01:17 PM   #128
Owner - RVtronics
Bob Fields's Avatar
Originally Posted by popeye59 View Post
Firedude,
... I will never own a Concertone unit again.
boo! ;-)
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Old 08-19-2010, 02:28 PM   #129
Originally Posted by Bob Fields View Post
boo! ;-)
Hey, I semi-recanted that in a different post on a different thread.
Frank and Jean
Retired Navy
DAV Life Member
popeye59 is offline
Old 08-19-2010, 02:48 PM   #130
Herk7769's Avatar
Is your tag line from the "Notebooks of Lazarus Long"?
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Closed Thread
