Closed Thread
Old 04-22-2009, 07:42 AM   #51
On my ZX550 I get a constant hum whle viewing TV- clean while watching DVD or cd. Hum changes in volume as brightness on TV picture changes. Happens while connected to cable or antenna. Any thoughts? Thanks.
Jrebhun is offline
Old 04-23-2009, 10:08 PM   #52
To All I have help in the past I'm sorry I have not been here to help you all. I was the only tech for the whole of ForrestRiver and on 9-11 of last year I had an indefinite lay off Do to them down sizing . I have not been able to find work since as I cant Find a job I will still try to help you if I can. Thank you. Fre Tech
Fre tech is offline
Old 04-23-2009, 10:23 PM   #53
Jrebhun
The hum your picking up is frome the converter you will need an inline condenser that will fix the hum for you
you can pick on up from radio shack it the same condenser you would put on the car radio
hope you find this helpfull
Fre Tech
Fre tech is offline
Old 04-23-2009, 10:27 PM   #54
Brittsnbirds
I would cut our an area inside the cabinet and run a 12v fan to circulate the air thorw to the systeam
I hope you find this help full
Fre Tech
Fre tech is offline
Old 04-24-2009, 11:30 AM   #55
Thumbs up thanks
Fre Tech,
Thanks can I run the 12v from the Concertone's power source? Probably should put the fan at the bottom and put an exit hole at the top for the heat to leave?
Thanks again.
Pat
2009 Chevy 2500 HD 6.0
2009 Wildwood LE 27RBEC
brittsnbirds is offline
Old 05-03-2009, 08:07 PM   #56
Grape Escape
No sound from main speakers
speakers A silent Both B(bedroom) and C (outside) working fine
Any ideas as to problem?
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline
Old 05-06-2009, 09:03 AM   #57
Fre tech-
I have a ZX75 in my Wildwood. I was trying to set the clock on the thing but the instructions are not very clear (at least to me). Is there a secret??
thanks
Pat
Old 05-12-2009, 04:52 PM   #58
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
After 2 season...I think I have the same problem as you. My outdoor speakers work fine...inside....not so fine.
It happened over the winter. Worked great until then. Any ideas?
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline
Old 05-26-2009, 05:54 PM   #59
Unhappy digital conversion
We have a Concertone ZX500 in our 2005 Rockwood 2701SS. We replaced our TV in the camper last year with a TV that has a built-in NTSC digital converter hoping that this would be sufficient since we assumed that the concertone was strictly analog. We made this purchase thinking that we could avoid using a converter box. Last weekend, we went camping for the first time and I tried it out. I selected the function AIR CHANNEL "X" but when I switched the TV to the DTV mode the TV was no longer running through the system. I must have the TV set to Video to be able to have everything run through the system which is bypassing the built-in tuner. Does this mean that I have to have the external converter box to be able to run it through the INPUT 1 function? Does this sound familiar to anyone? Did I waste the extra money buying the TV with the digital tuner since I am going to have to run the converter box external and use the INPUT function?
Can anyone answer this question?
Thanks for any tips in advance.
town63
town63 is offline
Old 05-26-2009, 08:02 PM   #60
Grape Escape
TV tuner
Personnally I would connect TV antenna directly to new tv and run RCA cords from sound ouput of TV to Concertone inputs if the damb thing still works. That way you will have much better picture reception from new tv tuner and still get sound out of trailer speakers. You could also run video out of concertone to tv input to use DVD from concertone unit.
dezolen is offline
Closed Thread
