Old 08-15-2013, 02:06 PM   #61
BillyBass's Avatar
Originally Posted by Hal View Post
I have cleaned mine several times already. When I do not have access to (or don't wish to use) a utility sink, I use a large plastic tub, such as a storage container, and fill it with soapy water. Then I dunk the grill and scrub it with a long plastic brush. I rinse it off with a hose and then set it in direct sunlight to dry as quickly as possible.
So far, I've had no issues with rust/corrosion - I make sure to move the gril around a bit while drying to ensure that any water that may be pooling somewhere gets to drain out fairly quickly.
Hope that helps!
That seems like to much work to me.that why I rather have a stove
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 08-15-2013, 02:57 PM   #62
tzh99h's Avatar
When I use my stove I spend 5-7 minutes after the meal cleaning any splashes, or grease spills that have landed on stove , to be clean and to deter any mice in future.
Now my barbque I set it up use it 1-3 meals every day for a weekend outing or week outing then when packing up I'll spend 5-7 minutes wiping all surface clean of grease(including under grate) and then with wet soapy rag wash barbeque and dry what I can and set it in the storage in a cardboard box like a pop case (to catch any missed dripping (soap or food particals)) till next outing. In my case Barbeque works the best for me.
tzh99h is offline   Reply With Quote
Old 08-24-2013, 08:20 AM   #63
Just Jammin 14's Avatar
We got the outside grill with our new Windjammer. Our concern is the heat from the grill against the side of the camper. Has anyone had any problems?
Just Jammin 14 is offline   Reply With Quote
Old 08-24-2013, 12:51 PM   #64
Oklahoma Proud
MillerTime's Avatar
I never have had any problems.
I did move it out from under the awning or roll the awning up when grilling.
I just got done making legs for the grill so I can move it somewhere else. I am also making a regulator with a quick connect so I can use the grill seperate from the rv port. ( just need a 1/4-3/8 pipe adapter that I will get this afternoon.)
ID:	38548   Click image for larger version
ID:	38549   Click image for larger version
Old 08-24-2013, 09:25 PM   #65
I have used mine about a dozen times and have had no issues with the side of our trailer. Seems to be adequate space between the grill and the trailer. PS: Turns out it is a great little grill. If you use a griddle it works great for eggs and bacon/sausage. Sure can't beat the convenience.
Acsimon
2008 Jeep Grand Cherokee (5.8 Hemi)
2013 Flagstaff Micro Lite 21FB
acsimon is offline   Reply With Quote
Old 08-24-2013, 09:38 PM   #66
Road-King's Avatar
I have used mine 1 time. I also didn't like it under the awning and so close to the trailer wall. I ordered a 10' extension for our next trip.
Camco 57282 10' Propane Quick-Connect Hose : Amazon.com : Automotive
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-24-2013, 09:49 PM   #67
SAILINGERIE's Avatar
I ordered one of these cheap POS with my new 2013 Windjammer. TOTALLY dissatisfied with it.....scrapped it at Omni-source. The Webber Q grills rock for grilling, you just have to remove the regulator to hook it up to the low pressure supply on the camper. A few fittings, hose and you are off to the races!
2007 F-350 DRW
2013 ROCKWOOD WINDJAMMER 3006W
SAILINGERIE is offline   Reply With Quote
Old 08-24-2013, 10:00 PM   #68
Thanks everyone for the input. It's much appreciated!
Old 08-25-2013, 01:43 PM   #69
BillyBass's Avatar
Mind came with the bracket for the side or the table
2014 14 nites
2015 16 nites
Old 08-25-2013, 04:52 PM   #70
Road-King's Avatar
X2
Russ & Kim
2014 Alpine 3600RS
