Old 09-16-2015, 08:48 AM   #1
deebarjay's Avatar
forest river lite trailers..range vent to outside.
never realized my vent fan wasn't sucking/pushing air out til now..checking outside under vent cap I see the thing is blocked with some cover...so how do you remove that thing...there are 2 knobby things on it, but push pull slide they will not budge.....anyone got some know how?
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 09-16-2015, 09:50 AM   #2
RichL
Rich70's Avatar
Vent covers are generally held closed during travel. Your cover seems different than mine. Generally they have two locking screws that twist to free the cover. Yours sounds like the cover has the screws on them. Have you tried turning them left or right?
Rich70 is offline   Reply With Quote
Old 09-16-2015, 10:10 AM   #3
Mr. Dan's Avatar
Can you post a picture so we don't have to guess what "knobby things" are?
If they are like the latches on my 'new style' vent flap, you push up on the latches with your thumbs with more force than you'd anticipate... but before that, check to see of there's caulk holding down the latches or the flap.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
Old 09-16-2015, 10:15 AM   #4
Lost Vermonters's Avatar
On mine the latches move (I forget in which direction) and that allows you to open the vent. Don't forget to close it before travelling.
After 17 years gone - Finally moved back to Vermont 2016.
2015 Microlite 21 FBRS
Silverado 1500 TV
Lost Vermonters is offline   Reply With Quote
Old 09-16-2015, 10:40 AM   #5
updhaul's Avatar
The exterior stove vent cover on mine has two plastic latches that turn down to allow cover to open when fan operates. Sounds like yours are stuck, if gentle pressure to cover and latchs doesn't allow them to break free (downward rotation for release) I would try some small amount of spray lubricant cleaning excess. Both are conviently located 6+ feet from ground level.
updhaul is offline   Reply With Quote
Old 09-16-2015, 11:19 AM   #6
I have a similar problem in my wildwood x lite. It does not seem like it is venting. Smoke alarm goes off EVERY time I cook. Pictures would help. I'll try and post some of mine tomorrow.
stantyszka is offline   Reply With Quote
Old 09-16-2015, 11:22 AM   #7
Your's sounds like the one I have push up on the two tabs and pull out that releases the flap. When you done just push the flap down and the tabs snap it into place. A photo will help!
edcronin01 is offline   Reply With Quote
Old 09-16-2015, 11:25 AM   #8
Renderspud's Avatar
I had the same issue. I had to push up and out on the tabs a lot harder than I expected. There should be 2 plastic tab latches on the bottom of the flap.
You push up on the 2 latches at the same time (harder push than you would expect) and then wiggle the tabs outwards. Eventually they will work loose and the flap (which is hinged at the top) will swing open.
After I got ours open I opened and closed it a few more times to break it in. Works easily now.
Renderspud is offline   Reply With Quote
Old 09-16-2015, 11:48 AM   #9
X2 Mine was so stuck I had to work the tabs with a screw driver. So I just let mine flap when traveling. Since it faces aft, I don't get water inside, even when raining. Sheesh!
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
Old 09-16-2015, 11:54 AM   #10
gastan's Avatar
X3 for the flap on my MiniLite.
2012 Rockwood MiniLite 2104
2007 GMC ECSB 2500HD Duramax
gastan is offline   Reply With Quote
forest river, trailer, vent
