05-25-2018, 10:42 PM
Freezer cold fridge not
We have a 2006 flagstaff 831qbss. We got to campground today around d 5. Plugged up power and everything. After 6 hours freezer food and cold. Fridge is still wArm. Are there any controls anywhere
05-25-2018, 11:01 PM
On our frig that means that the unit isn't level enough. Our refrigerator is very sensitive and needs to be very level.
2013 Itasca Ellipse 42QD
-2012 Lexington 265 GTS- Sold
Tow Vehicle 2017 GMC Acadia
05-25-2018, 11:09 PM
Double check the thermistor. UP is colder, DOWN is warmer. It likes to drop down while on the road. Also make sure the thermistor itself is actually UP inside the plastic holder.
2011 Traverse LT, 3.6L, FWD
05-25-2018, 11:49 PM
6 hours isn't enough time for the fridge to get cold.
The freezer always gets colder first. The fridge takes longer because it a bigger compartment.
Most of us let the fridge get cold overnight before leaving.
Your fridge doesn't work like a residential fridge, it works on absorption.
05-25-2018, 11:57 PM
Mine is usually cold in 4 hrs; at least cold enough to know it's working.
05-26-2018, 12:05 AM
For my fridge, 6 hours isn't enough for the fridge to be cold. Cool, yes.
05-26-2018, 12:27 PM
As mentioned above, the fridge takes longer to get up to speed. Our Dometic displays 60 degrees when turned on and takes time to get to the final 42 degrees when it hits our preset. If you have a display, it should start coming down after 5-6 hours and will continue down for more that 12 hours.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
05-26-2018, 12:43 PM
Citrus County, Fl.
Mine usually takes about 24 hours to get cold. It also helps if you don't put in drinks that are not cold yet. After 24 ours my readout is usually 34-37 degrees.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
05-26-2018, 01:40 PM
Ref
This may sound strange but I had the same problem with a 5 th wheel. I checked .every thing and finally discovered the switch that turned the ref lite bulb off was not working and kept the bulb on all the time which resulted in ref staying warmer. .the freezer was fine . Good luck.
05-26-2018, 01:58 PM
As a new RVer, I learned a lot from this question and answers. However, it made me think of another question. Do you travel with the refrig on? I have a 19' TT. On our very first trip, we turned the frig on on the start of our two hour trip to the campsite. Should we have done that?
Thanks.
John
2018 Forest River Flagstaff E-PRO 19FBS
2107 Toyota Highlander
05-26-2018, 02:30 PM
NC_RVer, As said above your frig can be turned on the night before you head out. We turn ours on several days before we leave, our frig takes a good day to get to the correct temperature. Know some will say theirs only takes a few hours, but that is just how ours works. We always travel with it on. Happy RVing
05-26-2018, 03:49 PM
FYI
Some info to increase your "professional aloofness" (LOL):
Some units have a Low Ambient Switch that actually bypasses the door switch and turns the inside light on. The heat of the light puts an increased "load" on the fridge. This switch is to be turned on when ambient temps are below 50 deg F in order to keep the cooling unit cycling. If you didn't do this, the unit would't run enough and the fridge would warm up inside.
See page 14, item X, for the switch and see page 18, paragraph 5.12, for a description.
05-26-2018, 04:38 PM
We always stick a bag of ice in ours for the first day, seems to help, I’ve heard of folks that freeze a jug of water and stick it in the fridge, when it melts you have water for coffee
OldSarg
05-26-2018, 04:50 PM
NC RVer,
Most RVers travel with the fridge on propane.
Is what you ran it on for the 2hr trip?
05-27-2018, 07:51 AM
Attachment 173362
In your picture - those fins - that what freezes up to be solid ice while we winter in Florida. At least 2x we have to take everything out and I then "blow dry" on those FINS!! After we camp this week, it is going back to the Dealer and our maintenance guy is going to keep 5th wheel for 3 weeks (have other issues) and deal with that fridge!!
Nikita
2020 Chevy Silverado Diesel 2500HD
2015 Sabre 33 RETS 5th Wheel
05-27-2018, 08:13 AM
Bikendan,
I believe I ran the frig on electric. We turned it on as we started our trip, drove directly to the campsite and then plugged in the TT.
BTW, I visited Camano Island, Washington a few decades ago. Beautiful place. The son of very close friends of mine owns Camano Island Coffee Roasters.
John
05-27-2018, 08:16 AM
It also makes a difference how hot it is outside. If it's very hot outside it will take a long time for the fridge to cool. We always turn ours on the day before we leave. I have never traveled with mine on but we have never ventured too far from home yet. Sounds like it's ok to travel with it on. I love this forum. It has given me such great advice and I have learned a lot. Thanks always to everyone for their contributions here.
05-27-2018, 08:22 AM
You're spoiled with your self defrost ref at home. I summer in MA for 4 months. Have to defrost at least twice during that time. Same for my little 4 cf electric ref on the porch with the beer.
05-27-2018, 08:31 AM
Turn on Fridge
I always turn on the fridge at least the day or two days before leaving on trip.
The fridge will cool faster on gas and when I leave home for the trip I leave it on gas until we get to camp ground.
I always set if for auto when starting out. But on gas cooling two days before trip.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2022 51 DAYS
[SIGPIC][/SI[SIGPIC]
