Old 08-17-2016, 11:55 PM   #1
2604WS
freezer ice
On our last two outings, the freezer has accumulated quite a bit of ice/frost. Searched the old posts and saw that it could be opening the freezer to often or bad seals. Don't think the opening frequency has increased which leaves us with the seals. Not being sure what a "bad" seal looked like I checked things out. What I noticed is that the seals on the top and sides were nice and aligned while the bottom seals had a noticeable sag. Is this what a bad seal looks like? Think this might be the culprit? I read where you basically have to replace the door.
Kirk
Name:	freezer top 1.JPG
ID:	117661   Click image for larger version
Name:	freezer top 2.JPG
ID:	117662   Click image for larger version
Name:	freezer bottom 1.JPG
ID:	117663   Click image for larger version
Name:	freezer bottom 2.JPG
kirkp is offline   Reply With Quote
Old 08-18-2016, 09:24 AM   #2
Head Rambler
Did you do the Dollar bill test? Where you close a dollar bill in the seal and see how hard it is to pull out. If it falls out on it's own, the seal is bad. If it takes a gentle tug to get it out the seal is intact.
While I've never replaced the seal on an RV fridge, those look like regular residential fridge seals.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-19-2016, 12:28 AM   #3
2604WS
freezer ice
Thanks Bama. I hadn't heard of that test but makes sense. Went to the TT today and gave it a try. The bill had the same resistance top, side or bottom. Heading out tomorrow so we'll see how it goes this time.
Kirk
Old 08-19-2016, 08:24 AM   #4
Head Rambler
You're most likely fine then. Probably just from all the extra humidity we've had this year.
Gotta go campin!
Old 08-19-2016, 08:27 AM   #5
SeaDog's Avatar
It has been years sense I heard the dollar bill test thanks for reminding me and I"m sure others
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
