Originally Posted by dcheatwood
A Forest River rep told me it will get colder if you move thermistor to a fin more towards the center of the frig. I never needed to try it tho. Make sure thermistor is in the top of the sleeve and sleeve is at top of fin.
The one thing that was not covered is the plastic slide that holds the thermistor.
Mine was loose enough that when I slide it up the fin, the thermistor slide down the sleeve. Moving the slide did nothing to the thermistor.
I had to drill a small hole in the slide. Then I used a tie-wrap to clamp the thermistor in the slide.
Now when I moved the slide up the fridge got down to 34F.
